Old 11-26-2011, 10:06 PM   #1
Curt R
Default 1939 Ford rear axle assembly
complete rear axle assembly
wide five wheel bolt pattern
torque tube and driveshaft
backing plates, hydraulic brakes, brake drums, brake lines, park brake cable
wishbone not split
shocks, rear sway bar, spring, all still bolted to rear frame crossmember and part of rear frame.
rear axle ratio-unknown
condition of rear axle gears and brakes-unknown
NOT INCLUDED are wheels and tires.
Complete assembly was under a 1939 Ford convertible, an old Wisconsin hot rod built and raced during the mid to late 1950's, stored in a barn until the mid 1980's then stripped for parts. Location of engine, trans and body, unknown.
Buyer must pickup, Milwaukee, Wisconsin.
$300.00
Curt R is offline   Reply With Quote
Old 11-26-2011, 10:13 PM   #2
Curt R
Default Re: 1939 Ford rear axle assembly
oops, should be in The Swap Meet" section. I don't know how to move it.
Curt R
