Go Back   The Ford Barn > The Swap Meet > Wanted > Early V8
Old 05-08-2010, 05:45 PM   #1
So. Cal.
So. Cal.'s Avatar
Default 1938 Ford Deluxe of 1939 Ford Standard Cowl
City: Oceanside
State: CA.
Does anyone out there have a 38 Ford Deluxe or 39 Ford Standard parts car? I am in need of the left and right sections of the cowl from the crease at the top of the cowl to the bottom or even the whole cowl if it will go greyhound.
So. Cal. is offline   Reply With Quote
Old 05-08-2010, 06:46 PM   #2
Sid the Maineiac
Sid the Maineiac's Avatar
Default Re: 1938 Ford Deluxe of 1939 Ford Standard Cowl
I have a 39 Standard cowl.It does need some repair at the bottom but would be very usable with a little work. If interested I'll get pictures to you by Monday I can ship Greyhound and believe it would be under $100.s/h. Will take $300. for the cowl.You tell me where you want it cut. Do you need the firewall with this?,Thanks,Sid
Sid the Maineiac is offline   Reply With Quote
Old 05-11-2010, 02:48 PM   #3
Sid the Maineiac
Please send an email address that works.Could not send pictures on [email protected] pictures of left and right cowl.
