#1 |
How much voltage should you have between the distributer and plug? According to my NuRex spark voltage tester, I have 20,000 volts between the coil and the distributer cap. However, when I put the tester between the cap and the No. 1 plug, I was lucky to get a steady 10,000 volts. I have an ancient original cap that looks in good shape an an old rotor that looks good. Is this voltage drop normal? Should I be adjusting the gap between the rotor and the terminals in the cap? Should I buy anew cap and rotor?
#2 |
I dont know how accurate the tester is , but a good running engine needs approx 5-8000 volts at idle total secondary ignition. Rotor and plug gap typically eat up 2-3000 volts in the gaps etc.
A new cap and rotor is always a good idea assuming the parts are quality parts..... |
#3 |
The last time that I touched a spark plug connector,the 'delivery' that I received felt as if I had taken a dose of AT LEAST 500,000V...TWICE. Since then, I have been able to pick up small ferrous objects using the back of my hand. Also, I have been told that the compass in my friend's 60's Caddy swings in my direction whenever I travel through his neighborhood. HMM?!?!?
#4 |
Although it might be nice to know, as long as you get a spark at the plug it's enough.
#5 |
If you just say ouch then it is weak. If you say oh sh t then it is ok If you say g d d m mf son of a b then it is real good. If you wake up in the hospital then tell me what you are using cause it is real good. |
