10-20-2011, 09:38 AM | #1 |
1940 Ford Vin numbers
I was wondering if the vin numbers that are stamped on the 40 Ford frame rails indicate what type of vehicle it is (coupe, 2dr sedan,4dr sedan).
Thanks |
10-20-2011, 10:14 AM | #2 |
Re: 1940 Ford Vin numbers
I don't think so,,,,but the gussets on the side of the frame will tell you if its a pickup or passenger car...if they are missing it's a pick-up
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford |
10-20-2011, 10:31 AM | #3 |
Convertibles have an extra set of holes for the cowl mounts,and are heavier gauge.
Milt/Las Vegas |
10-20-2011, 11:35 AM | #4 |
Ford's vin numbers (at least up to 1948 that I know of)offer no clue as to what body style it was.At least pass cars I think.Others will chime in I am sure.
10-20-2011, 11:57 AM | #5 |
frame numbers indicate year of manufacture, i believe....if there's a plate on the firewall, that might indicate body style.....Mike
10-20-2011, 01:18 PM | #6 |
10-20-2011, 03:43 PM | #7 |
Those numbers are sequential serial numbers within a model (No.) run. They have no significance as to the identification of the car. The numbers were assigned as the engine/ transmission assy was produced in the Rouge engine plant. Those assemblies were shipped out to the various assembly plants around the country. At the point where the engine/transmission was mated to a chassis on the final assembly line that number was read and stamped into the frame. The only piece of info you can glean from a Ford serial number is an approximate date of assembly-and that's only because records exist as to start and finish of a model run.
02-25-2016, 02:53 PM | #8 |
i am wondering if the 40 ford convertibles Vin number differs from the passenger car vins... can anyone help me thanks tommy
02-25-2016, 03:03 PM | #9 | |
02-25-2016, 03:09 PM | #10 |
Van Pelt Sales has a good article on this. http://www.vanpeltsales.com/FH_web/f...ialnumbers.htm
The number does not appear to tell what model the car is. |
02-25-2016, 03:34 PM | #11 |
Just noticed I screwed up the address. Try this:
http://www.vanpeltsales.com/FH_web/f...ialnumbers.htm |
02-25-2016, 05:24 PM | #12 |
Nope.
02-25-2016, 05:25 PM | #13 |
Those holes are in all frames. And, only the side rails are heavier gauge on the open cars vs. closed cars.
02-25-2016, 05:27 PM | #14 | |
add Feb. 26: I have been informed that the pickup frame is also a heavier gauge. Not being anything close to an expert on the PU's I will have to defer to Larry... He knows his stuff when it comes to the trucks. i keep learning...
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 02-26-2016 at 09:16 AM. |
02-25-2016, 05:29 PM | #15 |
Nope. However, there was a body number plate on the firewall that indicated the sequential order when the body was built.
02-26-2016, 12:42 AM | #16 |
Mike:
The pickup, convertible and wagon frame has a heavier gauge central x member than the other closed body passenger cars. You can tell this easily by looking at the two cone shaped holes for the anti-chatter rods. On the thinner closed car frames these holes use an added doubler plate and on the heavier frames these holes are only a single thickness.............Larry |
02-26-2016, 09:14 AM | #17 | |
The welded "pad" at the anti-chatter rod attaching point was welded to all frames beginning in mid 1939. My personal experience has borne this out on numerous convertible frames. As you know, I am just recently getting my feet wet on the pick up trucks. The wagons I have played with also had those pads welded in place. The only exception I've encountered was a very early 39 wagon.... VERY early.
02-26-2016, 10:58 AM | #18 |
I've never seen a body number plate with a sequential number on any 40 firewall I've looked at.The only plate that I've seen has patent numbers only.
Milt/Las Vegas |
02-26-2016, 11:48 AM | #19 |
02-26-2016, 04:15 PM | #20 |
MEMBER EMERITUS
I do know that on 1939 models, convertibles and pickups have about 3 circular cut-outs along each side of the rear diagonal chassis sections.
Passenger vehicle chassis do not have this feature. Last edited by swoopNZ; 02-26-2016 at 11:55 PM. |
