#1 |
I have a question concerning polishing paint after colorsanding. I have done some polishing with a 7" variable speed electric polisher. The problem I have is getting the polishing compound flung all over the place. I have tried different ways like starting real slow and using my hand to spread the compound over the area to be polished. I still end up with the polishing compound flung all over the place and making a mess. There must be a trick that I am missing or maybe not (it is always messy). If anyone has a good method of minimizing the mess, please post what it is.
Thanks in advance for any suggestions. Rusty Nelson |
#2 |
You may want to try a good orbital polisher like those sold by Griot's Garage - I think they are manufactured bt Porter Cable.
#3 |
I usually put the compound on the buffer pad then run it slow for a second or two, then speed it up. Seems to help a bit with the 'sling factor', as does not applying too much compound.
#4 |
