10-04-2011, 01:01 PM | #1 |
Piston to top of cyl.
Awhile ago there was a thread about pistons not going to top of cyl. I said I would post pic. I installed pistons today, EGGE 3 ring with 4in. crank in this Canadian early 40 block. The outside edge of the piston come just about to the top of the block. Hope pic works. Walt
10-04-2011, 01:23 PM | #2 |
Re: Piston to top of cyl.
Damn nice looking for a 71 year old. Too bad an old woman can't be built like that.
Alan |
10-04-2011, 03:25 PM | #3 |
Hey Walt,
I used .080 over EGGE pistons in my 49/50 Merc block and could not use the EAB heads. Jack 34pu |
10-04-2011, 05:27 PM | #4 |
I also had Merc. pistons hitting head with EAC heads. Same with EAB heads. Got a pair of 8CM and everything worked fine.
10-04-2011, 06:42 PM | #5 |
Yea guys, I know what you mean on the EAB heads, But I think you'll find the head that are hitting the piston have all been mill some. They are good heads but won't take much milling without flycutting over the piston. I just clayed a set of 38 heads on this engine today wth the EGGE pistons, the customer just had the heads milled and I was hopeing thay didn't take off much. I had .050 clearance in the middle of the piston and .040 on the lower edge of the piston, so I'm going to go with it. I do have to have the valve pockets flycut some. Walt
10-04-2011, 07:00 PM | #6 |
