09-30-2011, 09:46 AM | #1 |
1936 Ford Choke & Throttle Rod Joints
How are the choke and throttle rods attached to the rod joints on a 1936 Ford?
09-30-2011, 10:26 AM | #2 |
Re: 1936 Ford Choke & Throttle Rod Joints
Imarsch36-
This question comes up frequently. The correct way is to crimp the rods together using the sleeves. This is how the factory did it. However, I have always threaded the the rod ends and used a turnbuckle to tie them together. This allows the writing on the knobs to be aligned and also allows for easy disassembly if the dash knobs need to be removed. Tom |
09-30-2011, 10:44 AM | #3 |
Tom,
So you use a turn buckle instead of the rubberized rod joint? Larry |
09-30-2011, 10:48 AM | #4 |
Larry-
Yes, I use a turnbuckle. To the best of my knowledge, rubberized rod joints were never used by Ford on '35-'36 cars. Tom |
09-30-2011, 10:48 AM | #5 |
Rubberized joint wasn't used in 36,I know it was used in 1940
09-30-2011, 11:10 AM | #6 |
Thanks guys! |
09-30-2011, 01:30 PM | #7 |
When I installed the couplings for my 36 I ended up aligning the choke and throttle knobs and then used a wire feed welder and tack welded them. Replacement couplings were much harder steel and very difficult to crimp on the shaft.
09-30-2011, 02:22 PM | #8 |
You can accomplish the same thing using Loctite (for cylindrical objects) or one of the better glues such as J B Weld.
09-30-2011, 02:30 PM | #9 |
I have a 34 and used coupling nuts, they are a long threaded nut, 10/32 or 10/24 , then threaded each section and adjusted for the correct length and lettering alignment , a lock nut can be put on if you want but when installed they never move ... JMO .. AL
09-30-2011, 08:06 PM | #10 |
Slight change on this subject. How do you guys bend them so that they look alike as they go from the carb to the cowl?
Bruce/CT [email protected] |
09-30-2011, 08:25 PM | #11 |
I bend them in a soft jawed vice.
