09-24-2011, 03:36 PM | #1 |
Front Axle Measurements....
I've been looking all over the web and in the books that I have, for information on the front axle to be able to tell if it is still usable. I thought there was something somewhere that gave all the correct dimensions and angles so I could check a stripped down axle. Can anyone help? TIA, Jim
09-24-2011, 04:53 PM | #2 |
Re: Front Axle Measurements....
Here's some axle measurements I copied off of a webpage, and also a link to a section on straightening from the webpage of Kevin, one of the fellows whose on here frequently, which has info on the hole angles, etc.:
ORIGINAL AXLE MEASUREMENTS: 50-1/2" Kingpin Center to Center 36-1/2" Spring Perch Center to Center 2-1/4" Spring Perch Boss 1" Factory Drop .8125 dia. Kingpin 2-3/8" Kingpin Boss http://home.comcast.net/~68c/Front_a...aightening.htm |
09-24-2011, 05:16 PM | #3 |
