Old 09-22-2011, 07:36 AM   #1
GordonP
Default Package Tray
Working on 31 Cabriolet basket case with a rotten package tray (along with a lot of other things).
Hoping to find a better one at a swap meet. Will a 30-31 Coupe package tray fit? any others? - -I'm assuming a 28-29 tray is different.
Thanks for the help.
GordonP is offline   Reply With Quote
Old 09-22-2011, 07:46 AM   #2
30cabriolet
30cabriolet's Avatar
Default Re: Package Tray
Package trays have different depths and heights depending on year and if the car has a fixed seat or adjustable seat. '31 is an adjustable seat, so you need the narrower version. Also measure the height of your tray at the rear so you can get the correct tray. 28-29 would be wider and not be correct.
30cabriolet is offline   Reply With Quote
Old 09-22-2011, 07:57 AM   #3
jw hash
jw hash's Avatar
late 30 and 31 coupe package will work, I do have some early Cabriolet package trays that I cut back off and and welded them on a 30-31 tray so you can put an ajustable seat in the early Cabriolets
jw hash is offline   Reply With Quote
