Old 09-06-2011, 04:09 PM   #1
JAS1949
Default 36 Front Axle
Hi Guys, I,m new at this, bear with me. I've got a juiced axle 38 or 39, I guess. Is there any differences in measurements from this to a 1936.I noticed the perches are different, and the spindle pins. I've got 36 spindles, back plates, shocks, front spring. I would like to use this if I can.
Going back to mechanical brakes. Thanks loads guys. Lost Newbie
JAS1949 is offline   Reply With Quote
Old 09-06-2011, 05:36 PM   #2
Karl Wolf
Karl Wolf's Avatar
Default Re: 36 Front Axle
If you're going back to mechanical brakes, you'll need a 33-36 front axle... The brake linkage looks like it needs specific location for each component... 37 up axle will upset this... Karl
Karl Wolf is offline   Reply With Quote
Old 09-06-2011, 06:57 PM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
There are several difference between '33-'36 and '37-'41 front axles. Overall length, distance between axle purch pin holes and thickness of wishbone mounting pads. I would suggest finding a '33-'36 axle and forget that '38-'39. Advertise here in the wanted section and keep an eye on eBay. They are not difficult to find.
John
Old 09-07-2011, 10:53 AM   #4
blucar
blucar's Avatar
Are you sure you have a '38-39 front axle.. Converting early cars to hydraulic brakes was usually done by changing the spindles and king pins to '40-41 spindles, king pins and backing plates..
Bill.... 36 5 win cpe
Old 09-07-2011, 03:34 PM   #5
JAS1949
Thanks guys for your help. Now I need to know the measurement difference between a '36 & '37 up. Where do I measure & what's the measurements. Thanks Loads . I'm learning!!
Old 09-07-2011, 09:29 PM   #6
Harms Way
Harms Way's Avatar
I think I might still have a totally stock & complete 36' front end,.... I'll check.
A sinner saved by Grace,......... Eph. 2:8-9
Harms Way is offline   Reply With Quote
Old 09-08-2011, 06:39 AM   #7
Fordors
'33-'36 is 36 1/2 " CC on perch holes and the '37-'41 will measure 38 1/2" CC.
Fordors is offline   Reply With Quote
Old 09-09-2011, 03:19 AM   #8
JAS1949
Any luck on 36 front end?
