#1 |
I can't remember, is a Y-Block flywheel unique or can you use it on another engine?
#2 |
What I remember is not ever hearing of anyone using it on another engine, either 6 or V-8.
Mike, S. Oregon 46 Ford 1/2 ton, '62 Merc Meteor S33, '54 Ford 600 tractor, '64 Falcon Futura, 1960 Thunderbird |
#3 |
Y-blocks are internally balanced so it will swap to any other Y-block....I think.
Bill, certified Ford nut. 2024 F-150 2018 Lincoln MKZ 2016 Focus 1961 Comet S-22 1956 Ford Crown Victoria 36 Chevy, 351C/FMX, 8", Mustang II |
#4 | |
#5 |
all y block and 223.
#6 |
#7 |
I have a good , ready to use standard flywheel with a good starter ring that has already been resurfaced . It's very heavy but can ship for you . I am also going to be at the HAMB drags at Beaver County Drag way in Pa. on OCT 1 if you are coming and need the flywheel . I will be glad to bring it with me . The flywheel is $80 plus shipping .
Jim |
#8 | |
#9 |
Only good for a Ford Y Blocks , but I would hang onto it if it's a good one ! You never know when you might need it !
Jim, |
#10 |
You cant use it on any thing but a Y block in its stock configuration.
#11 |
They don't interchange with a flathead??
Mmmm Mmmm Grandma's cookin' |
#12 |
