Old 08-25-2011, 01:15 PM   #1
28 Special Coupe
28 Special Coupe's Avatar
Default Anyone tried a Nu-Rex timing wrench?
I'm just curious about that Nu-Rex timing wrench that the vendors sell.
Supposedly you use the timing pin to find TDC, loosen the cam screw, rotate the tool a few times, stop when it touches the #4 dstributer post, tighten the screw and you're done.
Have any of you actually used one of those things? Is it accurate? It just seems to good to be true. What do you guys think?
28 Special Coupe is offline   Reply With Quote
Old 08-25-2011, 01:35 PM   #2
newshirt
newshirt's Avatar
Default Re: Anyone tried a Nu-Rex timing wrench?
I used it. It worked fine. But then I reverted back to Marco Tahtaras' method because I wanted the most exact timing I could get. But the wrench probably does okay.
http://www.abarnyard.com/workshop/timing.htm
Ray White
newshirt is offline   Reply With Quote
Old 08-25-2011, 01:38 PM   #3
MCHinson
MCHinson's Avatar
I have a friend who has used it to time several Model A's. He highly recommended it, so I bought one. I have not had a chance to try it yet.
MCHinson is offline   Reply With Quote
Old 08-25-2011, 01:45 PM   #4
Aerocraft
Aerocraft's Avatar
I also have used it. It works as advertised. Gar Williams
Aerocraft is offline   Reply With Quote
Old 08-25-2011, 02:26 PM   #5
Mike in NRN IN
Mike in NRN IN's Avatar
Carry it in my tool box. It works every time I have had to use it (including on the road a couple times.)
I swear by it.
I also carry a bamboo 'skewer' in my tool box to find top dead center.
Take out number one spark plug.
Insert the skewer so that it is resting on the top of the piston.
Take out the timing pin (as normal)
Hand crank the engine and watch the skewer rise/fall
When the timing pin drops in, the skewer should at it's highest point
I have found a couple 'sloppy' dimples (I often have sloppy dimples, especially after eating corn on the cob) on timing gears and the skewer is a good visual cue to help in locating TDC.
Then use the Nu-Rex tool as instructed.
Flawless.
Mike in NRN IN is offline   Reply With Quote
Old 08-25-2011, 02:44 PM   #6
Jim Parker Toronto
Jim Parker Toronto's Avatar
I got one last year at French Lick, and it works great!!
Jim Parker Toronto is offline   Reply With Quote
Old 08-25-2011, 02:49 PM   #7
1931 flamingo
1931 flamingo's Avatar
I bought mine when they I found out about it. Simple and accurate. Worth the money. JMO
Paul in CT
Old 08-25-2011, 03:13 PM   #8
TinCup
TinCup's Avatar
Used one today on a 1930 standard coupe I was working on.
TinCup is offline   Reply With Quote
Old 08-25-2011, 03:20 PM   #9
MrTube
MrTube's Avatar
I just have to ask, being you control the timing advance by hand which is horribly inaccurate across the board, why does accuracy matter when setting the base setting?
I mean, as long as it starts easy and has enough advance at highway speeds is this not all that matters?
When I set ours, I used the Ford method, I then simply checked to make sure it was happiest idling with the lever around 1/8" down from the top and called it good.
MrTube is offline   Reply With Quote
Old 08-25-2011, 03:20 PM   #10
tuneman
tuneman's Avatar
Yep. Got one at snyders when they first came out. Love it
tuneman is offline   Reply With Quote
Old 08-25-2011, 03:24 PM   #11
Purdy Swoft
Purdy Swoft's Avatar
I haven't tried one. Does it allow for the backlash rotation? I set the timing by the trailing edge of the rotor tip when the timing pin drops in place with no clockwise backlash. not by the points. I don't think that there is a more acurate method. I've never felt the need to stick anything in the spark plug hole to find tdc. actually the piston rises above deck height when at top dead center. this will vary from one engine to another.
Old 08-25-2011, 03:33 PM   #12
Special Coupe Frank
Special Coupe Frank's Avatar
While the driver-controlled spark advance might be crude and "inaccurate" across the board, if the base timing is set-up carefully, then the driver should be withing fairly safe limits no matter where the lever is set.
If the base timing is set too "hot" or too "lazy", and the engine run with the lever at one extreme or the other, there is greater potential for engine damage...
My biggest frustration with setting the timing is the dealing with the backlash in the distributor drive when you go to tighten the cam screw down...
Just my mental meanderings...
With all this buzz about the Nu Rex wrench, my curiosity is piqued... I will have to check it out.
Special Coupe Frank is offline   Reply With Quote
Old 08-25-2011, 03:48 PM   #13
Special Coupe Frank
Okay, went to the Nu-Rex website and saw the timing wrench... wonder if I can use the same method with the off-set dizzy cam wrench I already have from Bratton's ?
Old 08-25-2011, 03:48 PM   #14
Bill in NJ
What does one of these things cost??
Bill in NJ is offline   Reply With Quote
Old 08-25-2011, 03:58 PM   #15
Special Coupe Frank
$9.95, plus S&H, according to the Nu-Rex website...
Old 08-25-2011, 03:59 PM   #16
Droobie
Droobie's Avatar
10.00 and it is indeed worth it. It takes all the guess work out of timing your A. Its one of the best things i have purchased for my Tudor..
Droobie is offline   Reply With Quote
Old 08-25-2011, 05:37 PM   #17
1931 flamingo
Special Coupe Frank: This tool, if you follow the directions, removes the backlash. Neat!!
Paul in CT
Old 08-25-2011, 05:45 PM   #18
Bill in NJ
I just looked and did not see it in the Brattons catalog. Any body got a picture of it??
Old 08-25-2011, 06:21 PM   #19
CarlG
CarlG's Avatar
This from Snyder's catalog:
Old 08-25-2011, 08:16 PM   #20
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
This is not some "new" magic wrench or procedure, it's just a more precise method of turning the distributor cam to the point where the points just break on #1 cylinder.
It's easier than turning it with your old, tired, forefinger and thumb. Even better than turning it with your favorite slip joint pliers!! ( the ones you stole from the wife's kitchen drawer )
"THE ASSISTANT GURU OF STUFF"
