Old 08-19-2011, 10:54 AM   #1
v8-60ford
Default oil pan baffle
What is the easy way to take out the oil pan baffle?
v8-60ford is offline   Reply With Quote
Old 08-19-2011, 10:55 AM   #2
1930artdeco
1930artdeco's Avatar
Default Re: oil pan baffle
I turn mine upside down-after the oil is all out and then take a 12" dift and hammer it out out through the oil drain plug opening. She pops right out after a good whack or two.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
1930artdeco is online now   Reply With Quote
Old 08-19-2011, 11:26 AM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
To me, the easiest is to hold it upside down at chest level, and drop it on the ground. If the flanged area of the pan hits flat upon the ground the tray pops right out.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-19-2011, 11:36 AM   #4
Greg Jones
Greg Jones's Avatar
What Brent said. Just raise the (empty!) oil pan about level with your head, and drop it squarely on the ground (not concrete). It will pop right out.
Greg Jones is offline   Reply With Quote
Old 08-19-2011, 11:47 AM   #5
Tom Endy
Tom Endy's Avatar
The way I remove them is to set the pan on the ground. Take a length of 2X2, a long wooden hammer handle, or a baseball bat. Put it down into the hole in the tray where the oil pump goes, put your foot on the opposide side of the pan, and give it a flick of the wrist.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 08-19-2011, 01:11 PM   #6
cpl624
cpl624's Avatar
Sorry for my ignorance, as I am a newbie. Why would you need / want to take it out?
Rick Aldrige
1931 Pickup
Pleasant Hill, MO (Kansas City)
cpl624 is offline   Reply With Quote
Old 08-19-2011, 01:19 PM   #7
Kurt in NJ
Kurt in NJ's Avatar
After trying screwdrivers the first time, dropping it etc. I came on a method like Tom Endys, I had my lift up about the heigth of the pan, slid it under some and use a length of pipe about 2" dia, it worked so easy I went and got 2 other pans and popped them apart also ---a lever down the oil pump hole and a quick kick would probably work too.
It needs to come out to clean under it.
Old 08-19-2011, 01:31 PM   #8
wrndln
Tom Endy's way is the easiest by far. I tried it and it works so well.
Rusty Nelson
Old 08-19-2011, 01:49 PM   #9
BRENT in 10-uh-C
But for me "e a s y" don't include goin' and finding a 2x4 (requires movin' stuff off the top of it to find one) and then findin' a baseball bat --or an unbroken hammer handle long enuf to reach down in there (but not good enuf that I would care about submerging in the "oily goop"), ......then cleanin' my tennis shoe up after my foot slipped and my shoe landed in the remaining sludge at the bottom of the pan, ...and then goin' and cleaning out the parts washer first so I have room to put 'Juniors' baseball bat in there to clean off the once-hidden grease from under the tray that has now made a mess on his handle, ...followed by spending a few minutes finding a clean rag to wipe off Junior's Baseball Bat (--or wipe off the remaining piece of my now broken hammer handle).
Like I said, for me the easiest ....
BRENT in 10-uh-C
Old 08-19-2011, 01:52 PM   #10
MrTube
MrTube's Avatar
I just take it and use the palm of my hand and slam it down flat onto a piece of thick cardboard on a concrete floor. The baffle goes pop! everytime.
No need for 2x4s or bats.
MrTube is offline   Reply With Quote
Old 08-19-2011, 02:32 PM   #11
CarlG
CarlG's Avatar
Originally Posted by MrTube View Post
...No need for 2x4s or bats.
The 2x4's and bats are for the guys that are laughing at you trying to get it out!
Old 08-19-2011, 02:47 PM   #12
v8-60ford
Thanks for info poped right out.
Old 08-19-2011, 02:47 PM   #13
James Rogers
James Rogers's Avatar
I do it like Mr Tube and Brent. I take out 20 or so a year and have only seen one that wouldn't come out this way. It was welded in and the welds were covered with sludge so I couldn't see the welds. I ground them off, straightened the pan sides and reinstalled it after cleaning, worked fine.
Old 08-19-2011, 06:19 PM   #14
MrTube
MrTube's Avatar
For me trying to get the baffle out, no. But for me trying to install the pan and gasket yes I'm sure there would be plenty of laughing.
The first time the gasket fell half in the pan and I didn't realize. I don't like doing oil pan gaskets.
Old 08-20-2011, 03:56 AM   #15
Tom Wesenberg
Tom Wesenberg's Avatar
You need to remove the sludge and also inspect the oil pan bottom for pin holes caused by the sludge.
Old 08-22-2011, 09:27 AM   #16
Elcastor
Elcastor's Avatar
Then you need to inspect the rim after all that dropping!
Ben Purkey
Mexico and the Pacific NW
http://www.martin-parry.com/
Elcastor is offline   Reply With Quote
Old 08-22-2011, 10:07 AM   #17
MrTube
MrTube's Avatar
We need to get something straight.
It is not a drop, it is a accurately controlled descent with a very abrupt stop.
