Old 08-13-2011, 03:09 PM   #1
Ron Lowe
Default Am I asking for trouble
In the process of replacing my fan I was thinking about changing the 4 studs for the water pump to the new bolts that look original. They say you can remove the pump without removing the radiator. My big question is how hard is it to remove the four studs? Sometimes I hate to mess with something that isn't broke. What would you guys do? Thanks again Ron
Ron Lowe is offline   Reply With Quote
Old 08-13-2011, 03:28 PM   #2
TinCup
TinCup's Avatar
Default Re: Am I asking for trouble
Funny you should ask this question today. I just got through helping my buddy do this on a 1930 Sedan. 3 came out easy. 1 broke off and we are still working on getting it out.
TinCup is offline   Reply With Quote
Old 08-13-2011, 05:24 PM   #3
John Duden
John Duden's Avatar
if it was me i would replace them with the origional, but for me it would probable break them all off! but that is just my luck
John
John Duden is offline   Reply With Quote
Old 08-13-2011, 06:25 PM   #4
glenn in camino
glenn in camino's Avatar
Keep the original studs, replace the fan with an aluminum 2 blade. The 2 blade fan allows you to remove the waterpump by removing the hood but without removing the radiator. Just pull the radiator forward, rotate the 2 blade so it's horizontal and the waterpump will come right out.
glenn in camino is offline   Reply With Quote
Old 08-15-2011, 12:48 PM   #5
28 Special Coupe
28 Special Coupe's Avatar
I replaced my 4 studs with the new bolts without any problems at all. I applied some liquid wrench on them and let it soak in for a few hours. The studs came out easily with vise grips.
28 Special Coupe is offline   Reply With Quote
Old 08-15-2011, 01:18 PM   #6
johnbuckley
johnbuckley's Avatar
Yes, totally agree. Have a try using penetrating oil and either visegrips, or good pliers adjacent to the block, if they don't want to budge easily, leave them for if/when you have to have the radiator out,. As always if it ain't broke don't fix it.
johnbuckley is offline   Reply With Quote
Old 08-15-2011, 01:31 PM   #7
Milton
Milton's Avatar
"New bolts that look original"?
Whazzat? Picture or reference please.
Milton is offline   Reply With Quote
Old 08-15-2011, 01:43 PM   #8
1931 flamingo
1931 flamingo's Avatar
If you've got a snyder's catalog (or go on line=waterpump) pg A-127 ,right column, p/n A-8501-MBM 1928-31 $5.50 set. I have them but haven't installed yet.
Paul in CT
Old 08-15-2011, 01:45 PM   #9
CarlG
CarlG's Avatar
Bolts that are machined to look like the original studs and nuts. Makes removal of the water pump much easier with the radiator on the car. Sold in sets of four. U.S.A. Snyder's Part # A-8501-MBM
Old 08-15-2011, 02:13 PM   #10
Milton
Milton's Avatar
Good Lord, now I have seen it all!
That's enough to gag the average purist.
I am a believer in "form and function".
Do my eyes deceive me or is that an O-ring that I see? I do, however, believe the star locks are going a little to far. Oh well.
Old 08-15-2011, 04:06 PM   #11
hardtimes
hardtimes's Avatar
Well these have been available for some time!
And, if you ever have had to 'tear down' your radiator/hood/whatever else....just to get the B/O fan out...well it wouldn't take long to see where this 'little' invention is qenious. No O-ring..just some permatex/schmutchem seal as usual !
hardtimes is offline   Reply With Quote
Old 08-15-2011, 04:13 PM   #12
Doug in NJ
Doug in NJ's Avatar
I was a cheapskate, and made my own by lok-titing (or krazy-gluing, I forget) nuts to the stock studs.
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 08-15-2011, 04:33 PM   #13
Marco Tahtaras
Marco Tahtaras's Avatar
Maybe it's just me, but this strikes me funny
. I can see them having a problem creating raven finished studs in this manner. But then they ship them with Shakeproof washers instead of split lock washers? Did they make the batch too short to use proper lock washers?
Yep, "lets make something that looks sort of original but lets throw
something in so everyone can tell it's our product"!
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 08-15-2011, 04:57 PM   #14
Milton
Milton's Avatar
I have really never had that much of a problem removing a water pump, except with the four bladed style fan.
Old 08-15-2011, 07:05 PM   #15
Gary Gregory
Gary Gregory's Avatar
I just removed the old studs from my 30 coupe. Two on bottom came out easy but the two on top were tuff. Vicegrips were useless...i used 2 of the nuts that came off the stud...jammed one against the other and soaked the stud with lots of PB Blaster. It took a while but I got them. Used those new "fake" studs from Snyders.
Gary Gregory is offline   Reply With Quote
Old 08-15-2011, 09:55 PM   #16
Ed in Maine
Getting a stud out of a casting that has broken off flush usually can be removed by the following method:
1. Take a flat washer that has a hole in it that matches the diameter of the broken stud.
2. Tac weld the flat washer to the end of the stud in a couple of places.
3. Weld a nut to the flat washer and then back the broken stud out with a box wrench.
Good luck, Ed
Ed in Maine is offline   Reply With Quote
Old 08-15-2011, 10:18 PM   #17
mrtexas
mrtexas's Avatar
Removing studs you have to be prepared to break one. Then?? You have to be prepared to get the broken one out.
mrtexas is offline   Reply With Quote
Old 08-16-2011, 12:17 AM   #18
Jason in TX
Jason in TX's Avatar
Mine from brattons came with lock washers and no o rings.
They work great and have had them on three cars. No one has ever noticed them.
I love them because they make life MUCH easier now that I'm an expert on water pump replacement. Knock on wood that I don't have to change another one on the side of the road.
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 08-16-2011, 07:00 AM   #19
Mitch//pa
i have them on 2 cars with lockwashers and no orings also... i think they would even fool the fine point judges
Old 08-16-2011, 09:09 AM   #20
5window
5window's Avatar
The amazing thing is that no matter where you start, the first three will come out easy-and the fourth one breaks off.
5window is offline   Reply With Quote
