Old 08-13-2011, 10:51 AM   #1
cpl624
cpl624's Avatar
Default gas guage question
This morning I got all my stuff together to put a new float on my gas guage. Got the old one out with no problems. Went to put it back in with new gaskets, and now I am confused. Where the guage assembly actually contacts the gas tank there looks like there should be a gasket. In my new kit there are two different ones that "fit" that area. One is black neoprene looking and the other is a teal color thinner neoprene style. There was no gasket in that area when I pulled it apart, only what looks like remnants from where one used to be.
Which gasket goes where? Thanks for any assistance.
Rick Aldrige
1931 Pickup
Pleasant Hill, MO (Kansas City)
cpl624 is offline   Reply With Quote
Old 08-13-2011, 11:07 AM   #2
J Franklin
J Franklin's Avatar
Default Re: gas guage question
There is usually a flexible gasket (cork, paper, or neoprene) against the tank and then a brass shim type to allow the screw bezel to turn freely to tighten. don't know who supplied the kit but the brass washer is important.
Old 08-13-2011, 11:19 AM   #3
cpl624
cpl624's Avatar
I got a genuine ford kit from Snyders. Got the brass ring also, and there was two in place already when I pulled it out. I found a video on youtube that showed a guy changing one on a 29. He just stuck the black gasket on the tank and started tightening the unit back in place. I am still not sure where the other larger gasket would go. The kit also came with smaller black gaskets that I guessed were for the actual glass seals. I did not take that area apart so I didn't figure I would need those.
Rick Aldrige
1931 Pickup
Old 08-13-2011, 12:39 PM   #4
cpl624
cpl624's Avatar
I must have done something right. Just took it for a test drive and nothing is leaking. Wierdest thing is the odomoter is now working also. I must have jarred something while putting the instrument panel back. I wonder how long that will last.
Rick Aldrige
1931 Pickup
Old 08-13-2011, 07:01 PM   #5
J Franklin
J Franklin's Avatar
The extra gaskets are for when you drop one in the dirt or it pops into the gas tank when big fingers get in the way.
The bags with Ford logo are supposed to be licensed by ford and Who knows the quality that is demanded to carry this.
Old 08-14-2011, 07:49 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
It's been a couple years since I bought a gas guage gasket kit, but they used to come with cork or neoprene. I only use cork. Seems several guys that used the neoprene had problems when the 10% ethanol crap gas got to it.
Old 08-14-2011, 05:32 PM   #7
RonC
RonC's Avatar
It's tank, gasket, main gauge, brass washer then the nut.
RonC is offline   Reply With Quote
Old 08-14-2011, 10:32 PM   #8
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
The only thing demanded is that the royality check clears.
Old 08-15-2011, 08:23 AM   #9
John LaVoy
John LaVoy's Avatar
I think they actually had two or three of the brass washers so that the gauge would not rotate when the nut was tightened. The original gas gauge tool did not allow you to hold the gauge level while turning the nut.
John LaVoy is offline   Reply With Quote
Old 08-15-2011, 01:32 PM   #10
Dave / Franklin MA
Dave / Franklin MA's Avatar
I just repaired my gas guage recently. I believe they provide a thick and thin gasket so you can use either one (or both) depending on how the outer nut happens to seat on your particular car. It doesn't look "right" if it sticks too far out or is inset too far compared with the dashboard. With the proper combination of thin and thick gaskets you can adjust how it sets when it's tightened up, and get it to look the way you want it to.
Dave / Franklin MA is offline   Reply With Quote
Old 08-15-2011, 01:37 PM   #11
1931 flamingo
1931 flamingo's Avatar
One fellow on a previous post swore by coating these "washers" w/maple syrup to ease installation. Seriously.
paul in CT
Old 08-15-2011, 08:55 PM   #12
Dave / Franklin MA
Maple syrup might work good or maybe not. Honestly, I'm waffling on that idea.
