Old 07-28-2011, 01:12 PM   #1
John Walters
John Walters's Avatar
Default Which turn signal kit to use?
I have a 30 Pickup, with two tail lights, want to add turn signals to rear. Mac's has a "lighting wire harness-with built-in turn signal wiring-without cowl lamps-for 2 bulb system". Is this what I need? Do I have to add turn signals to front, or can I do it to rear only with this kit? Please clarify "2 bulb system"
Thanks.
jw
John Walters is offline   Reply With Quote
Old 07-28-2011, 01:36 PM   #2
CarlG
CarlG's Avatar
Default Re: Which turn signal kit to use?
I bought my kit from Sacramento Vintage Ford. They have their own wiring shop and the pre-wired the switch and fabric covered all the wires. Works perfect and looks good as well. It is set up to use either the tail lights or separate lites in the rear, and for the front it is set up to use cowl lights, the parking lights in the 2-lite headlights, separate lights, or I suppose, none in the front, although I don't know why you wouldn't want something in the front as well.
It utilizes the legacy Signal-Stat controller that is period correct for the Model A.
Old 07-28-2011, 01:44 PM   #3
1931 flamingo
1931 flamingo's Avatar
When I did mine I bought a signal stat stalk, flasher assy, 2 rear between the bumper lights and found a pair of Ford foglights (w/patina) for the front, ran my own wires thru the orig type woven loom avail fron the vendors and wired in the orig tail lights. Now I have four stop lights in the rear.
Paul in CT
Old 07-28-2011, 02:34 PM   #4
Ron in Quincy
Ron in Quincy's Avatar
I prefer the Logolite system; it is complete with LED lights front and rear which mount between the bumper bars, or if you have no rear bumper you can use your tail lights for the rear. The system will work on 6 or 12 volt, negative or positive ground. the control unit mounts on the dash with a magnet; its has a buzzer that operates when the signal is on so you cannot forget to turn off; also has lights that flash on the control unit.
Put up logolite.com and you can see the system, what it includes, and what it looks like.
Ron
Ron in Quincy is offline   Reply With Quote
Old 07-28-2011, 02:47 PM   #5
Jack '29 Sport Coupe
Jack '29 Sport Coupe's Avatar
I vote with Ron....Logolite is the sweetest system I have ever seen. It is super easy
to install and you don't have to do any fancy wiring.
Jack
Cincinnati, Ohio
Jack '29 Sport Coupe is offline   Reply With Quote
Old 07-28-2011, 03:57 PM   #6
RcT
Well, upon the words of all you folks above, I have finally ordered a Logolite set-up for my '29 Coupe, justifying the cost by calling it "cheap insurance"... I am soooo vulnerable. But no more gas-saving gimmicks!
RcT is offline   Reply With Quote
Old 07-28-2011, 04:45 PM   #7
bobgreco
bobgreco's Avatar
I have the logolite system also and think it is really nice and blends in rather nicely.
bobgreco is offline   Reply With Quote
Old 07-28-2011, 05:15 PM   #8
Michael in Sedona
Michael in Sedona's Avatar
I'll add my name to the list of LogoLite fans. I have them on the roadster, and they really work nicely. I wasn't real thrilled with the suggestion to place the control box on the face of the dash panel, though. I put mine below the seat on the steel riser. You can't see it there, and it's easy to just feel the left or right buttons and know you have the correct light working.
Michael in Sedona is offline   Reply With Quote
Old 07-28-2011, 05:20 PM   #9
700rpm
700rpm's Avatar
The correct web address is http://www.logolites.com/led/turn/signals/index.htm for logolites.
Old 07-28-2011, 05:32 PM   #10
CarlG
CarlG's Avatar
Old 07-28-2011, 06:04 PM   #11
Bruce Adams
Bruce Adams's Avatar
You can purchase a knock off SIGNAL STAT 800 for less thatn $20 at many vendors to include GASLIGHT AUTO PARTS, in Ohio, I believe.
I have had mine on for about 8 years and it works perfectly in daily driving, utilizing my stock rear lights and cowl lights. Duo parking lights would also work if you have dual lamps in your headlight bucket.
The flasher and flasher holder cost about another ten dollars.
Bruce Adams is offline   Reply With Quote
Old 07-28-2011, 06:44 PM   #12
Clydes 31 P/U
I'm REAL cheap I just used a 3 way toggle switch. I used the cowl lights in the front and found some old arrow signal lights and then for extra noticability I put 2 wire sockets in the tail lights. I did put the turn signal beeper that the venders sell in it.
Clydes 31 P/U is offline   Reply With Quote
Old 07-28-2011, 08:23 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
I'm even cheaper! I use my left arm. Nothing to buy! LOL
Old 07-28-2011, 08:29 PM   #14
CarlG
CarlG's Avatar
And I'll bet 99% of the people think you are just drying your nails!ROFLMAO
Old 07-28-2011, 08:33 PM   #15
mrtexas
mrtexas's Avatar
Thanks.
I believe the two bulb system means the headlight bulb and parking bulb in the headlight bucket. Why would you only want to have rear turn signals?
I like the built in wiring. It uses the parking lights in the front and the standard rear tail lights. I bought fog lights and use them as the turn signals in front. I have a right hand tail light as well. I also bought the Ron Meister turn signal black box sold by the usual vendors as well which works good with the built in wiring. The box uses a phone line to a small micro switch mounted on the gear shift lever. Kind of spendy but I don't like the clunky looking typical steering column mounted turn signal set up. The box also has a built in buzzer so you don't forget to cancel the turn signals.
BTW, I mounted 3 LED trailer lights on my 28 RPU for stop lights and high stop lights. Not standard, but they WILL see my stop lights.
mrtexas is offline   Reply With Quote
Old 07-28-2011, 09:11 PM   #16
RTC1930
RTC1930's Avatar
I'm thinking about using the control box from this kit with a momentary switch like Clydes under the dash and cloth wiring from one of the vendors. I have not heard anything about them though so I'm not sure if its a good recommendation or not but its another option.
http://turnswitch.com/Turnsignal.htm
"Fix what's broken"
RTC1930 is offline   Reply With Quote
Old 08-06-2011, 06:29 PM   #17
RcT
Thanks to all the good words from you folks, I ordered the Logolite system and installed it this afternoon. Sweet, clean easy installation and nothing was drilled or damaged in any way... completely reversible. Thank you, gentlemen.
Old 08-08-2011, 04:51 PM   #18
ldj1002
I also made mine from scratch. I hid toggle switch behind dash paned and the flasher behind kick panel. Can't see anything except the 2 clearance light on the rear bumper. Cost less than $20.00
ldj1002 is offline   Reply With Quote
