Old 05-07-2010, 08:53 AM   #1
Joe KCMO
Joe KCMO's Avatar
Default Adjusting a 39 steering box
I just completed assembling and I believe adjusting the steering box on my 39 coupe. Anyone have tips or insight on how to do it right would be appreciated.
Joe KCMO is offline   Reply With Quote
Old 05-07-2010, 09:01 AM   #2
Ross in East Texas
Ross in East Texas's Avatar
Send a message via AIM to Ross in East Texas
Default Re: Adjusting a 39 steering box
First, center your pitman arm. Remove the cap and star locking washer from the roller adjustment. Tighten the adjusting screw until slack/freeplay is removed when you turn the wheel. Replace the star locking washer and cap and you are done. If all the slack can not be removed then there is excess wear in your components.
Ross in East Texas is offline   Reply With Quote
Old 05-07-2010, 09:08 AM   #3
Joe KCMO
Joe KCMO's Avatar
I do not have the box in the car. Can I do the same thing by just centering the range of travel (in the middle, equal turns each way)?
Old 05-07-2010, 09:38 AM   #4
Ross in East Texas
Yes, as long as the roller is centered in the worm gear you are good to go.
Ross Murphy
1939 Ford Standard Coupe
Old 05-07-2010, 10:04 AM   #5
Joe KCMO
Joe KCMO's Avatar
Thank you. This new format is working very well for me.
Old 05-07-2010, 11:19 AM   #6
Mac VP
Mac VP's Avatar
This link to our site shows the complete procedure for the 37-48 steering gearbox adjustments:
http://www.vanpeltsales.com/FH_web/f...tmt1937-48.htm
Mac VP is offline   Reply With Quote
