Old 07-03-2011, 12:51 AM   #1
Zim
Zim's Avatar
Default Fuel tank/instrument panel ID
Greetings all,
I'm going to use the fuel tank from this cowl for my '30-'31 wagon project. This cowl was used on a Gordon Smith air compressor and was originally part of a Murray body (M654 3XXX). The cowl band uses 4 carriage bolts on each side, plus clips on top.
Can you guys tell if this tank used the round or oval instrument panel based on this picture and information? I can take more pictures and measurements later if needed.
Thanks!
Zim
Zim is offline   Reply With Quote
Old 07-03-2011, 01:19 AM   #2
48Ratfink
48Ratfink's Avatar
Default Re: Fuel tank/instrument panel ID
Round!
48Ratfink is offline   Reply With Quote
Old 07-03-2011, 05:52 AM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Originally Posted by 48Ratfink View Post
Round!
Not really sure how you summised that as I would tend to think with that particular cowl band that this would be an early cowl which would have used the earlier oval speedometer. What am I missing??
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-03-2011, 06:52 AM   #4
Richard Wilson
Richard Wilson's Avatar
I would rebuild the GS compressor and find another gas tank if it were mine. A picture of the other side would help answer your question about speedo easier.
Richard Wilson is offline   Reply With Quote
Old 07-03-2011, 08:17 AM   #5
48Ratfink
48Ratfink's Avatar
I am new to Model A's ,, I thought all 30, 31 used round speedometer! However I have seen alot of Your posts and do trust Your knowledge.
I stand corrected!
Old 07-03-2011, 08:36 AM   #6
Steve Plucker
Originally Posted by Zim View Post
Greetings all,
Thanks!
Zim
Zim...
Brent is correct. That is a very, very early cowl section as one can tell by the "full" length of the cowl band.
Second, the tank goes along with the cowl as being a very, very early 1930 tank. It was generation # 1 as far as the 30-31 tanks are concerned. The reason there are "clips" for holding the cowl band in place on the top is because there are no embossings on the tank itself to secure the A-140298 Cowl Moulding Assembly to the tank.
This tank, as Brent says, utilizes the 28-29 instrument panel with the "oval" speedometer.
You can read all about it in a soon to be released Model A News (MARC).
Pluck
Old 07-03-2011, 08:40 AM   #7
Steve Plucker
Nothing!
Pluck
Old 07-03-2011, 10:40 AM   #8
Zim
Zim's Avatar
Thanks for your replies and helpful information. I don't have anything else from the GS, but this tank is extremely clean and straight.
Zim
Old 07-03-2011, 10:56 AM   #9
Frank Nemo
Frank Nemo's Avatar
I stand corrected!
The early 1930s (May and earlier) utilized the oval speedometer and the dash light in the middle of the dash panel. My May 6,1930, San Francisco built, Sport Coupe, bears this out.
Henry didn't want to waste anything!
Frank Nemo is offline   Reply With Quote
