Old 06-27-2011, 06:36 PM   #1
james heider
james heider's Avatar
Default Converting a leatherback to steelback
Has anyone converted a leatherback 4 door or Victoria to a steelback?
I have a leatherback and I am considering converting it.
james heider is offline   Reply With Quote
Old 06-27-2011, 08:53 PM   #2
Richard Wilson
Richard Wilson's Avatar
Default Re: Converting a leatherback to steelback
Obviously all those tack holes for the leatherback top material will have to be welded up. The metal panel around the rear window will have to be replaced. The metal top pieces where the gutter attaches would have to be changed out. You might be better off to try and swap your leatherback body for a steelback body?
Richard Wilson is offline   Reply With Quote
Old 06-27-2011, 09:10 PM   #3
Roadster62
Roadster62's Avatar
I have a 1929 60C Steelback rear section that I'd like to build a body around. Found four doors locally that I'll pick up this weekend if all goes well. I need a 60C cowl and visor, they differ from the leatherback 60A&B.
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 06-28-2011, 08:22 AM   #4
jw hash
jw hash's Avatar
it is pretty easy if you can find a back half of a steel back, but if not don`t do it, the whole back half from the belt up is different I have built both body`s, the wood is different even the inside brace for the spare tire is different the rain gutter are welded on, good Luck John
jw hash is offline   Reply With Quote
Old 06-28-2011, 08:57 AM   #5
james heider
Thanks John and Richard for your reply. I was working on the body yesterday and was wondering how difficult it would be to convert it to a steelback.
I didn't realize that the rain gutters were welded to the body.
Old 06-28-2011, 09:10 AM   #6
Jason in TX
Jason in TX's Avatar
I had always thought I would be a steel back owner until a leatherback came along at a great price. One of the immediate benefits I saw in my leatherback which was stored outside for 2009 and 2010 was that because the leather wraps over the metal roof opening and all the way down to the driprails, the interior and headliner was not damaged by water. Ive been in a few touring sedans with waterstained upholstry. Its difficult to seal those tops. Also the light colored vinyl reflects a lot of heat as opposed to the black insert. So far I've been quite happy. You might find that all that work might not be necessary
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 06-29-2011, 07:18 AM   #7
Brian SATX
Brian SATX's Avatar
Another differencein the leatherback/steelback Victoria is the size of the rear window. One is taller than the other.
Brian SATX
Brian SATX is offline   Reply With Quote
Old 06-29-2011, 07:23 AM   #8
jw hash
jw hash's Avatar
the rear windows are the same size and use the same inner window frame
Old 07-01-2011, 08:13 PM   #9
metalshapes
I just did this conversion, and posted about it on the HAMB.
I'll copy the Thread here on the Ford Barn later, but if you want to see it right now here is the link.
http://www.jalopyjournal.com/forum/s...d.php?t=603835
metalshapes is offline   Reply With Quote
Old 07-01-2011, 08:38 PM   #10
D-Russ
D-Russ's Avatar
I've done it. Here's a link to my thread on the HAMB:
http://www.jalopyjournal.com/forum/s...d.php?t=321871
Now taking donations of money, parts or both. Inquire via PM.
D-Russ is offline   Reply With Quote
