06-26-2011, 08:07 AM | #1 |
Line Boring a model A for inserts
Hello'
I am building a new engine block to put in my car,and I would like to use inserts. I've been laid off from my job ,and won't be called back till the end of aug... so the cost of a babbitt re-pour is out of the question.What I need to know is if when I remove the old babbitt , is the block machined the correct distance from the camshaft? I have a line boring machine , but no dedicated way to set it up for a model A block.My machine centers by sweeping a dial indicator in the housing bore , looks to me like I can make it work if the housing bore under the babbitt is the proper distance from the camshaft holes......I have already installed sleeves in the cylinders , seats for the valves ,and cut down the stem length on some big valves that were to long ,resurfaced the block ....spent less than $125 so far............thanks..... JIMI |
06-26-2011, 02:07 PM | #2 | |
Re: Line Boring a model A for inserts
06-26-2011, 02:53 PM | #3 | |
06-27-2011, 08:33 AM | #4 |
JIMI |
