Old 06-20-2011, 11:29 AM   #1
1928Pickuppain
1928Pickuppain's Avatar
Default Model b carb settings
what should the Gav Settings be for a model b carb on my A i removed the helper spring and put all new fule lines in her and she is running like a champ just a bit rich. and dose any one have a decent technique for perging the gass tank without removal
1928Pickuppain is offline   Reply With Quote
Old 06-20-2011, 01:52 PM   #2
Larry Seemann
Default Re: Model b carb settings
Model B carbs are designed for the GAV to be turned completely closed once the engine is warmed up.
Larry Seemann
Larry Seemann is offline   Reply With Quote
Old 06-20-2011, 08:00 PM   #3
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I have a late 31, so I was able to flush the tank pretty easily. Then I installed a dirty leg, which is working great. I'm not sure how you would flush a "prototype" tank, with the gas valve inside?
Old 06-20-2011, 09:35 PM   #4
Cape Codder
Cape Codder's Avatar
Should the GAV on a Model A carb, (Zenith) shut off the fuel to the engine if turned all the way in?
Thanks for your time.
Joe Grobleski
Cape Codder
Cape Codder is offline   Reply With Quote
