Old 06-15-2011, 03:28 PM   #1
leadpot
leadpot's Avatar
Default Gas in Gas Gauge
Filled up my Tudor last night. On the way home I noticed that there was gas sloshing around inside the fuel gauge - no gas was leaking out of the gauge or dash. Is this normal or dangerous - do I need to rebuild my gauge?
Tried a search but did not find any info.
Leadpot,
leadpot is offline   Reply With Quote
Old 06-15-2011, 03:29 PM   #2
Farrell In Vancouver
Farrell In Vancouver's Avatar
Default Re: Gas in Gas Gauge
Sounds normal to me as the back of the glass is in direct contact with the fuel
Farrell In Vancouver is offline   Reply With Quote
Old 06-15-2011, 03:57 PM   #3
V4F
V4F's Avatar
when FULL you will see gas . as said above , that is you gas tank !
V4f
V4F is offline   Reply With Quote
Old 06-15-2011, 04:04 PM   #4
RonC
RonC's Avatar
Does your gas gauge tell you how much gas is in your tank? The new gas will swell out the cork float and sink it. If your getting a zero full when you have gas you will need to replace the cork float with a neoprene one.
RonC is offline   Reply With Quote
Old 06-15-2011, 04:13 PM   #5
roccaas
roccaas's Avatar
And pull out the cork gaskets around the gas gauge and replace with Neoprene.
Somewhere I read that the design of the gas gauge was to allow the gas to "wash" the back of the gauge.
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
Old 06-15-2011, 04:18 PM   #6
Jason in TX
Jason in TX's Avatar
Hehe. I had to smile at this one.
Your gas gauge is actually a glass window looking inside your gas tank.
This is what the gauge looks like
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 06-15-2011, 04:32 PM   #7
hardtimes
hardtimes's Avatar
Leadpot,
Leadpot,
You got a smile from me on this one!
How long have you owned an A? Just have to ask, as I know everyone else wants to know..but won't ask.
Fords gas scheme, including 'guage' is quite simple/inqenious. Also simple to fix/repair if needed. If your guage is NOT leaking, that's good. If you can see graduated black numbers/bars(indicating gallons in tank)that's even better. If you have a full tank of fuel these days(at $4+ gal)..take a nice long drive and enjoy life!
hardtimes is offline   Reply With Quote
Old 06-15-2011, 04:59 PM   #8
newshirt
newshirt's Avatar
Follow-on question: Do you have to empty the gas tank to change the cork float?
Ray White
newshirt is offline   Reply With Quote
Old 06-15-2011, 05:05 PM   #9
Jason in TX
No. fuel level just needs to be lower than the gas gauge.
Old 06-15-2011, 05:16 PM   #10
Jack '29 Sport Coupe
Jack '29 Sport Coupe's Avatar
If you don't see gas it means you are out of gas!
Jack
Cincinnati, Ohio
Jack '29 Sport Coupe is offline   Reply With Quote
Old 06-15-2011, 06:33 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
On the gas guage glass you want to use ONLY CORK, not the neoprene.
Old 06-15-2011, 06:57 PM   #12
Jason in TX
Cork floats dont work after a couple of years of sitting in this lovely E85 gas. Go for the neoprene float.
In fact, I would put the neoprene on the gauge glass, not cork, seeing as how the gas ruins the cork in the tank.
Old 06-15-2011, 09:01 PM   #13
leadpot
leadpot's Avatar
Well, I have had my first "A" about 4 months. This is the first time I had got a full tank as I had a gas leak problem (now solved) before this & did not want to fill it too full.
I'm learning bit by bit & hope you got a chuckle from a newbie. By the way I just noticed my engine has no spark plug wires - whats up with that
Leadpot
Old 06-15-2011, 09:11 PM   #14
cpl624
cpl624's Avatar
Leadpot.
From one newbie to another, we are learning together. Had my '31 pick-up about three weeks now. I had the same thought last Friday night when I filled mine up for the first time. I didn't dare say anything outloud, as my wife is a worrier. She would never have slept thinking our house is going to explode at any moment. I hope to drive the gas down enough this weekend to try to fix my gauge.
Here in the Kansas City area, I have to buy marine gas to keep from getting 10% ethanol blend, and have to drive a ways to get it. But after seeing what the ethanol has done to my small engines I plan to buy the marine gas, and the neoprene float. Cork bits in the tank does not sound like a good time.
Next time I will ask the "silly" question and take some heat for us "newbies".
Rick
cpl624 is offline   Reply With Quote
Old 06-16-2011, 12:47 AM   #15
hardtimes
hardtimes's Avatar
Originally Posted by cpl624 View Post
Leadpot.
Rick
Hey, no 'heat' intended for sure! You two are doing what this site is/was intended for, i.e.- helping each other and having fun with this old ford stuff , whether it be bone stock or slightly 'improved'! Sure wish it had been around back when, as it ain't necessarily fun to learn the hard way! Just think of it this way...In my case, I'm smiling because I've been there too, as I suspect most of us have! What you get here. you can't put a price on,eh! Some of these guys are probably more knowledgable(about the details of the entire car) than ford was!!
So don't be put off by varying opinions (neoprene vs cork). Ask your questions...swing away! You'll find that there's more that one way to 'skin a cat' . Oh, by the way, install a battery cut off switch...for peace of mind and a lot of other good reasons.
Old 06-16-2011, 07:34 AM   #16
Chris in WNC
Chris in WNC's Avatar
Default a contrary opinion regarding gaskets......
when I replace gas gauge gaskets, I always use cork with Permatex.
based on my experiences and that of many friends, neoprene will leak sooner than cork.
new type float is much better than the old cork ones.
I know that's not logical, it's just what works for me........
no more model As for now........
Chris in WNC is offline   Reply With Quote
Old 06-16-2011, 10:09 AM   #17
mjw
mjw's Avatar
My 30 roadster has a brass float like in a carb much better than neoprene and cork. Not sure if it is correct but it came that way.
mjw is offline   Reply With Quote
