Old 05-26-2011, 09:43 AM   #1
48Ratfink
48Ratfink's Avatar
Default On to next project!
I have the peel and stick running board rubber,,,,any advice before I tackle this??
48Ratfink is offline   Reply With Quote
Old 05-26-2011, 10:15 AM   #2
JunkOSC
Default Re: On to next project!
I couldn't get mine to stick very well. I had to removed all the peel and stick material from the rubber and use contact cement to get then to adhear.... making sure the boards are extremely clean.
JunkOSC is offline   Reply With Quote
Old 05-26-2011, 10:36 AM   #3
Mitch//pa
same here i used weatherstrip adhesive. even if you do get it to stick in the heat it will lift in spots and youll have large bumps.
