05-15-2011, 09:35 AM | #1 |
How to repair door hinge bolt holes??
Can anyone tell me how to repair the bolt holes on a 29 CCPU door and frame. I can't seem to get the taper made. Any ideas? The holes are wobled out and I can weld them up and redrill them but how do I make remake the taper to use the original tapered screws??
First Parts Done! |
05-15-2011, 09:52 AM | #2 |
Re: How to repair door hinge bolt holes??
You need a countersink
The screws are probably 82 degree included angle. You should be able to get one at a good hardware store. Make sure your welds are annealed before you drill and countersink the holes. Joe
1929 Tudor since 1962 Feather River A's |
05-15-2011, 10:27 AM | #3 |
You need to make a jig to line up the new holes if you weld things up. Hopefully there is enough of the original hole to center things.
05-15-2011, 03:58 PM | #4 |
Also a Dremmel or die grinder and stone with the correct angle might work well for this.
05-15-2011, 07:37 PM | #5 |
The taper that I'm refering to is on the sheet metal side.
First Parts Done! |
05-16-2011, 12:49 AM | #6 |
Like I said I have not done this, but I think that is you were to "over countersink" the steel to account for the thickness of the sheet metal it should work.
