Old 05-11-2011, 05:16 PM   #1
Roger1950
Default 36 pickup windshield install
I have the glass and the frame. The hinges I bought from Macs did not fit. Is there a mounting bracket that actually connest the hinges to the frame? I do not want a hinged winshield but need to know how I can secure the frame to the body.
Thanks
Roger1950 is offline   Reply With Quote
Old 05-11-2011, 06:51 PM   #2
Don Rogers
Don Rogers's Avatar
Default Re: 36 pickup windshield install
Roger, There are 2 brackets that attach to the windshield frame and they attach to the hinges.
Don Rogers is offline   Reply With Quote
Old 05-11-2011, 08:45 PM   #3
Lawson Cox
Lawson Cox's Avatar
Be sure you get the brackets for the pickup. Passenger car brackets are different. Angle is different.
Old 05-12-2011, 09:23 AM   #4
freddys35
The Second pic is of hinge bracket installed in cab. The First is of the hing bracket out of truck. The 3rd is the other half of hinge beside a mounted hinge. The 4th is of the 2 pieces. The 5th is the hinge bracket in reference to the windshield, with other half. The 6th is a different view of pic 5. Confused, call Fred 214-803-5895
freddys35 is offline   Reply With Quote
Old 12-22-2011, 09:30 PM   #5
Ridgewood 36
Is there anyone that sells the hinge to winshield frame brackets for a 36 ford truck?
Ridgewood 36 is offline   Reply With Quote
Old 12-22-2011, 10:06 PM   #6
Lawson Cox
Lawson Cox's Avatar
Someone if reproducing the hinge bracket, but I think it is for passenger car only. You see them on ebay occasionally.
Old 12-23-2011, 01:30 AM   #7
Fe26
All that hardware just to make a window open... just a little bit. lol
Fe26 is offline   Reply With Quote
Old 12-23-2011, 12:24 PM   #8
robert dick
there is a pair of hinges on the -epay 36 ford site now!
robert dick is offline   Reply With Quote
Old 12-23-2011, 03:14 PM   #9
Ridgewood 36
I have the hinges, I need the brackets that mount the windshield frame to the hinges. Thanks anyway. From what I can tell these brackets are like hens teeth.
Old 02-05-2012, 08:53 AM   #10
36Bill
36Bill's Avatar
Is the difference between the frame for a 36 car and a 36 pickup the brackets or is the frame different also? Could I use a car frame and change out the brackets on my pickup?
Bill
36Bill is offline   Reply With Quote
