Old Yesterday, 04:39 PM   #1
Klattu1929
Default steering gearbox oil
I am currently rebuilding a 2-tooth steering column/gearbox. The 7-tooth in my car currently I used Penrite semi fluid gearbox lube. For this 2-tooth I am looking at trying the Millers Oils vintage worm steering box oil, sold on Amazon. Has anyone used this or is it not a good product for the 2-tooth gearbox. Planning to do the swap next winter so thought I would get a jump on the Barn opinions. Thanx.
Klattu1929 is offline   Reply With Quote
Old Yesterday, 05:27 PM   #2
Jim/GA
Jim/GA's Avatar
Default Re: steering gearbox oil
If you are sealing it up well, use the 600W oil you use in the transmission. Use the end plate with tube. The o-ring and flat washer at the end of the sector shaft when you bolt it to the frame helps.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old Yesterday, 05:45 PM   #3
Marshall V. Daut
I mix a 50-50 solution of 600w and STP oil treatment in a cup and then carefully (and slowly) pour this syrup into the gear box. It's thick enough to help reduce the leakage of 600w by itself and the STP clings to the gear surfaces to keep them lubed.
Marshall
Old Yesterday, 05:54 PM   #4
Joe K
Joe K's Avatar
My solution is John Deere Cornhead Lube. https://shop.deere.com/us/product/AN...dge/p/AN102562
Yup. A grease. But probably the most "transitional" grease I've seen.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old Yesterday, 06:42 PM   #5
Kube
Super Moderator
Kube's Avatar
Joe K
Joe, like you, that's all I use. I made a fitting with a grease zerk so I was able to easily fill the box. Then, once full, I'd sway the fitting for the authentic plug.
Old Yesterday, 06:54 PM   #6
Synchro909
Synchro909's Avatar
Joe K
That has also become my go to. I used to use the same Penrite lubrication that the OP mentioned but when I found out about corn head grease, I switched and have never regretted it. I put it into the steering box by using a syringe without the needle.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old Yesterday, 07:09 PM   #7
nkaminar
nkaminar's Avatar
I am a proponent of modern 85W-140 gear oil because of the additives that reduce wear. The box must be sealed well and the end plate with the tube must be used.
Old Yesterday, 09:04 PM   #8
old ugly
old ugly's Avatar
like above.
cornhead grease. buy it from the John deere dealer it is cheap. pump that in there but make sure all the other oil is out.
thixotropic. turns to liquid state from friction then back to grease when not in friction.
old ugly
my mom would have told me. "these things are here to test us"
old ugly is online now   Reply With Quote
Old Today, 12:38 AM   #9
updraught
updraught's Avatar
Careful cleaning is needed for cornhead grease.
"Polyurea grease compatibility is highly unpredictable because polyurea thickener chemistries vary widely. While some polyurea greases mix perfectly fine with lithium or calcium greases, many are completely incompatible. Mixing incompatible greases causes the thickener to collapse, resulting in severe oil bleed, hardening, or liquefying, which often leads to bearing failure."
https://www.machinerylubrication.com...-compatibility
updraught is offline   Reply With Quote
Old Today, 11:28 AM   #10
Klattu1929
You guys have given allot to think over, I did use cornhead in my u-joint. And I think the tube on the end plate is an excellent idea. I need to do more research on cornhead for the steering box application. I will go by the local Deere dealer and quiz the mechanic. Got a box of 2-tooth parts coming today. Got 6+ months to get the old brain box to make a decision, thanx, guys.
Old Today, 04:16 PM   #11
old31
I don't think the deere dealer will know too much about a Model A 2 tooth steering box.
I would just use the cornhead.
Old Today, 08:09 PM   #12
Y-Blockhead
Y-Blockhead's Avatar
I use Penrite Steering Box Lubricant. Since it doesn't leak out I probably have enough for the next 25 years.
Old Today, 08:15 PM   #13
old ugly
old ugly's Avatar
they may not know what a model A steering box is but they will definitely know what Corn Head Grease is. they had a whole rack of it when i bought mine. i think it was under $10.00cdn per tube.
old ugly
Old Today, 08:17 PM   #14
Jim16A1
Does corn head grease get warm enough to actually flow through a steering box that isn’t generating very much heat through friction? My 7-tooth box’s lower bearing fell apart and the pieces aggressively galled the shaft because the previous owner tried to use that stuff instead of gear oil. I’d vote for proper sealing, running gear oil, and using the lower plug with the extended tube.
Jim16A1 is online now   Reply With Quote
Old Today, 08:19 PM   #15
old ugly
old ugly's Avatar
it is not heat that makes it change form. it is friction.
old ugly
Old Today, 08:21 PM   #16
Keith True
Keith True's Avatar
They will know what it is,but they will know nothing about it.I worked for a JD dealer for almost 5 years,we knew what it was for,and where to use it,but that was the extent of it.Nobody trained us on the different properties of greases.We had no reason to.We did use it in the steering boxes of the 2 cylinder tractors,just seemed to be a practical use for it.We also used track and roller grease in those old steering gear boxes too.
Keith True is online now   Reply With Quote
