Old 06-01-2026, 11:53 AM   #1
ted55ford
ted55ford's Avatar
Default Brake lights needed for my 55 Fairlane...
Hello all,
I upgraded my brake master, Im looking for a part that would fit on my line. A T fitting perhaps?...Or is a brake pedal extension needed? Please have a look at my setup...
Thanks
Ted.
File Type: jpg cfdef48f-d9b2-45b4-afc0-6ed0c31637c9.jpg (43.6 KB, 20 views)
1955 FORD FAIRLANE
1967 FORD MUSTANG CONV.
ted55ford is offline   Reply With Quote
Old 06-01-2026, 01:17 PM   #2
evintho
evintho's Avatar
Cool Re: Brake lights needed for my 55 Fairlane...
I used a generic brake light switch. Welded one tab to the pedal support assembly to mount the switch and another tab to the pedal itself to trigger the switch. Works great!
https://www.fordbarn.com/forum/attac...1&d=1780337821
evintho is offline   Reply With Quote
Old 06-01-2026, 03:54 PM   #3
paul2748
paul2748's Avatar
Default Re: Brake lights needed for my 55 Fairlane...
I made up a bracket that mounts on the dash/firewall brace and used an aftermarket switch (electrical) on my 54 Ford. I have a write up about it if you are interested. Message me your email and I can send you the info.
If you prefer to use an hydraulic switch, you can get a T fitting at a local auto parts store that will take a standard hydraulic switch.
Based on your picture, you could substitute that coupler on the back line with the T fitting.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 06-01-2026, 09:45 PM   #4
cjshaker
cjshaker's Avatar
Ford used to use pressure activated switches in the '60s, which I've used on '50s cars, using a T fitting coming off the master. It was an easy job, but to be honest, evintho's set-up is much nicer and cleaner.
