Old 06-01-2026, 11:10 AM   #1
petehoovie
petehoovie's Avatar
Default Tech 101: Oil Viscosity Versus E85 > From Hemmings
When using E85 as a fuel instead of straight gasoline, the recommendation is to use one step higher grade viscosity engine oil than what you would otherwise use. For example, if you were planning to run 10w30 engine oil the suggestion would be to step up to 10w40. This compensates for the thinning effect of alcohol-based fuel because of the significantly greater amount of fuel required when running E85. Alcohol has been shown to act like a solvent with oil. This is why you would increase viscosity. This is especially true with carbureted E85 engines as they often run much richer air-fuel ratios. A great follow-up suggestion would be to test your used oil to ensure it is not compromised with excess fuel or alcohol in the oil. Several companies offer this service including Amsoil, Blackstone, and SpeeDiagnostix.
https://www.hemmings.com/stories/tec...9b1bcf9b99e50a
Old 06-01-2026, 12:56 PM   #2
John R
Default Re: Tech 101: Oil Viscosity Versus E85 > From Hemmings
Interesting article. However, I doubt any of us are using E85, especially in our carbureted engines. There also may be reasons other than fuel dilution not to use E85.
Those who do not move do not die, but are they not already dead?
John R is online now   Reply With Quote
Old 06-01-2026, 01:06 PM   #3
19Fordy
19Fordy's Avatar
Thanks Pete for posting that info. Hope E85 gets the DEEP 6 ASAP.
Old Yesterday, 09:17 AM   #4
leon bee
I've never even met anyone who used E85 in anything.
leon bee is offline   Reply With Quote
