Old 05-23-2026, 03:30 PM   #1
jeepguy1948
Default Radiator Cap Vented?
Is the ‘30 radiator supposed to be vented? Mine is not vented. If it’s a non pressurized system I would think that the cap needed to be vented. After finding that I had repop Gas Cap with a non functioning vent I decided that I better check about the Radiator Cap as well.
jeepguy1948 is offline   Reply With Quote
Old 05-23-2026, 03:33 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Radiator Cap Vented?
No, no vent in the radiator cap. The radiator is vented via the overflow tube.
Old 05-23-2026, 03:38 PM   #3
jeepguy1948
Thanks Blockhead.
Old 05-23-2026, 08:04 PM   #4
katy
katy's Avatar
The cooling system is vented through the radiator overflow tube.
Old 05-24-2026, 04:12 AM   #5
German guy
German guy's Avatar
It is vented via the overflow tube!
German guy is offline   Reply With Quote
Old 05-24-2026, 11:13 AM   #6
The Master Cylinder
The Master Cylinder's Avatar
I agree with all of these answers!
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 05-24-2026, 11:22 AM   #7
Marshall V. Daut
The radiator and gas tank caps look alike between the years 1928-29 and 1930-31 respectively. But - they are different internally. The gas cap IS vented, while the radiator cap is not, as others have posted. It wouldn't hurt anything to run a vented gas cap on the radiator (although you might get some "weeping" coolant droplets from underneath), but you cannot run a radiator cap on the gas tank. Because the fuel system in a Model A relies upon gravity, it must a source of fresh air intake somewhere to allow nature's gravity to make the gasoline flow to the carburetor. If that air intake source is closed off (via an unvented or clogged vented cap), insufficient fuel will reach the carb and the engine will act like it is running out of gas - which it is. There will be enough of a fuel trickle to keep the engine idling, but will peter out as power demands are required.
Marshall
Old 05-25-2026, 07:31 AM   #8
chap52
chap52's Avatar
Good reminder Marshall,
Had a Gas Cap vent plug up 30 miles from home and remembered what I had read on a Forum about that possibility. I loosened the cap and watched it jiggle as I drove the rest of the way home.
I then drilled a couple of extra vent holes in the interior part of the cap. All was well. Chap
chap52 is offline   Reply With Quote
