Old 05-22-2026, 10:56 AM   #1
LJ48
Default radiator cap replacement
On my 1950 Club Coupe with a 296" Flathead V8, the radiator cap is a very old lever type cap. I want to replace it with a 4# regular cap, but the filler neck is 3/4' deep instead of 1" which I understand is normal. The only I.D. I can find on the radiator is Jake's Radiators. It is a brass radiator. The caps that I can find are for the deeper filler neck so they won't close. I want to stick with the low pressure cap since I have the original heater. I have read many posts on the site, but mostly they discuss low vs high pressure caps, not the depth difference. Has anyone else found a solution for this?
Thank you,
Larry
LJ48 is offline   Reply With Quote
Old 05-23-2026, 09:31 AM   #2
Drbrown
Drbrown's Avatar
Default Re: radiator cap replacement
I don't know about a '50 ford but a 4 lb cap is stock for '47-'48 and I think they went to an 8 lb later.
Drbrown is offline   Reply With Quote
Old 05-23-2026, 12:07 PM   #3
Bob C
Try a Stant 10208 says fits a 3/4" deep neck. 1953-64 Ford tractor or 1952-56 Ford pickup with OHV engine.
Old 05-23-2026, 01:01 PM   #4
LJ48
Thank you guys. I double checked, and the factory service manual says the manual trans V8s were pressurized systems to 3 1/2 to 4 1/2 pounds. That Stant number crosses to a MotoRad T4 which I have found.
