Old 05-19-2026, 11:07 AM   #1
ted55ford
ted55ford's Avatar
Default Carpet install and back seat removal--55 Fairlane
Hello all,
Im installing a new carpet(4 dr) but want to keep it simple. Is there an easy way to remove the 4 seatbelt anchors? I dont want to replace the belts.
Also is there a good method to remove the back seat to access the trunk, Ive only removed the seat portion?....Is there a special tool I should be using in both of my questions?
Thx.
1955 FORD FAIRLANE
1967 FORD MUSTANG CONV.
ted55ford is offline   Reply With Quote
Old 05-19-2026, 07:06 PM   #2
miker98038
miker98038's Avatar
Default Re: Carpet install and back seat removal--55 Fairlane
My easy way is to buy a 6 pack of his favorite, and then call my buddy with the longest arms. He can usually reach far enough to hold the nut with a breaker bar while I take it out from the top. Either that, or get it high enough to get under it. Either way, it’s pretty much 2 people. Sometimes you might be able to wedge a wrench on the top and do it alone from underneath. But that’s usually an exercise in frustration for me.
You cut holes for the bolts in carpet before?
I can’t speak for your car back seat, but with the seat cushion out there’s often bolts at the bottom that let the clips at the top slice out.
miker98038 is offline   Reply With Quote
Old 05-19-2026, 07:33 PM   #3
paul2748
paul2748's Avatar
You got the bottom cushion out YES? Is so, at the bottom of the back rest there should be two bolts that hold the bottom of the back rest. I don't remember what is at the top, but noting you shouldn't be able to deal with.
If you don't have the bottom cushion out, based on my experience with other fords all you have to do i pull up from the front and it will slide out
rear seat removal has always been a one man operation as far as I was concerned.
Can't you access the seat belt bolts from the trunk ?
Worse comes to worse, you can always cut them near where the two parts of the seat meet and push the remainder into the trunk.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 05-20-2026, 12:20 PM   #4
Dos Cincos
Dos Cincos's Avatar
The top part of the backseat lifts up out of a french cleat type bracket that runs along the top of the package tray.
Dos Cincos is offline   Reply With Quote
