Old 05-17-2026, 11:49 AM   #1
old31
Default LEDs for parking lamps
Has anyone found any LED’s that are short enough to work in a 30/31 roadster cowl lamps?
Old 05-17-2026, 01:29 PM   #2
Trapdoor2
Trapdoor2's Avatar
Default Re: LEDs for parking lamps
Not sure if there's a difference but I'm running the amber LEDs in my Coupe cowl lamps. Same size as the dash and dome light. I got them from Snyders. I'm 6v.
'31 Ford Deluxe Coupe "The Green Hornet"
Trapdoor2 is offline   Reply With Quote
Old 05-17-2026, 02:33 PM   #3
BButturff
BButturff's Avatar
Logo Lites #63 LED bulbs are the same length as incandescents but they are only listed for 6 volt.
_______________________
The other Bruce in Minnesota
1931 Model A Closed Cab (Budd) Pickup "Aurora"
Model A Ford Club of America
Lady Slipper A's
"You can't go back and change the beginning,
but you can start where you are and change
the ending." - C.S. Lewis
BButturff is offline   Reply With Quote
Old 05-17-2026, 04:19 PM   #4
old31
Thanks, I will order the #63's.
Old 05-19-2026, 09:56 PM   #5
ModelA29
ModelA29's Avatar
https://www.ebay.com/itm/38692184220...Bk9SR5rZ6LTIZw
ModelA29 is offline   Reply With Quote
Old 05-20-2026, 08:21 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
The 1930-'31 cowl lights are the same except that some have a screw instead of a rivet attaching the bulb socket to the body.
Bob Bidonde
Old 05-20-2026, 11:32 AM   #7
Keith True
Keith True's Avatar
I bought LED lamps for the tail,cowl,and brake from Snyders.Almost any flavor will do,as they are used to BE SEEN,not to see with like a headlight.
Keith True is offline   Reply With Quote
Old 05-27-2026, 10:12 AM   #8
old31
Does anyone know of a dual filament, LED bulb that will work in a 30/31 roadster cowl lamp?
Old 05-27-2026, 02:21 PM   #9
DF Model A
DF Model A's Avatar
The folks at classicautobulbs may have what you are looking for, however, I imagine you know it's not as straight forward as just swapping out incandescent bulbs with LEDs. You likely will also need to install load resisters to each since your resistance flasher may not recognize the low wattage LED. You can upgrade to an LED flasher but that likely opens a whole new can of worms with the rear stop/turn signal lights unless you plan on a complete LED conversion all around. Hope this helps with your research.
Apparently, I cannot post a URL until I have 10 posts, so please add the 3 w's and a dot com to the above source.
DF Model A is offline   Reply With Quote
Old 05-27-2026, 03:08 PM   #10
30Murray
Don't understand how you can use a dual filament bulb in a single base cowl lamp holder, but try here:
https://www.ledlight.com/6-volt-posi...ed-lights.aspx
btw, I used bright 240 lumen LED's in my cowl lamps and have them wired to a separate switch to use as daytime running lights. I have a similar setup in another car with two-light headlights.
30Murray is offline   Reply With Quote
Old 05-27-2026, 05:03 PM   #11
old31
FYI.
I have leds in the rear on my 6 volt system. All 4 corners of the car have directionals. The cowl lamps have been wired for both parking lamps and directionals, but I have been using regular bulbs for the last 5 years. The bulbs finally burnt out, so I thought I would look into LEDS.
Old 05-28-2026, 08:04 AM   #12
Badpuppy
ledlight.com 64218 should work, but you may need to add a ballast resistor like DF says.
Badpuppy is online now   Reply With Quote
Old 05-28-2026, 08:15 AM   #13
old31
That will not work. The photo shows dual filament, but the description says:
Rebaydo 2pcs BA15D 6 Volt 60 SMD 5730 "Single Filament" Reduced Profile.
Made with total 60 leds, 44 side firing and 16 forward firing. This lamp is a "single filament" bulb.
Old 05-28-2026, 08:23 AM   #14
CT Jack
CT Jack's Avatar
I use the 6v amber LED lamps listed in Snyders catalog as A-13466-ALED. They also have white. I like the amber becauce it is more visible during daylight. I use my cowl light as a directional light as well. This is much more noticeable than having directionals on the bumper.
CT Jack is offline   Reply With Quote
Old 05-28-2026, 08:52 AM   #15
Badpuppy
Correct, I forgot there are 2 types, 1 filament between contacts an 2 between contacts and shell. 62417 is the one you need.
Snyder's A-13464 (2 ea.) can be connected between each tail lamp and ground so the thermal flasher works. Electronic flashers are susceptible to ignition noise, causing erratic operation.
Old 05-28-2026, 04:42 PM   #16
CarlG
CarlG's Avatar
I bought mine from:
Classic Dynamo and Regulator Conversions Ltd
Part #
21/5w Amber/White BA15/BAY15
Item# 246215Ws
These shine white when just the cowl lights are on, amber for turn signals
12 volt, 2 contact sockets
Alaskan A's
Model A Restorers Club
Mullins Owner's Club
