Old 05-11-2026, 06:37 PM   #1
roenidoc
roenidoc's Avatar
Location: village in low mountain range 40 miles east of cologne
Default Front brake Problem
I'm having problems with the front brake on my Model A: it squeals when I brake hard and sometimes seizes up when I come to a stop. It seems like something is loose. Overall, though, the braking performance is good, and the car hardly pulls to one side. - When I removed the brake drum for inspection today, I noticed that there is no key in the groove at the end of the axle (as there is in the rear). And the axle isn’t smooth; it has grooves. Is a key missing? If so, will the rear axle key fit in?
Greetings from Germany,
Chris
Ford Model A Fordor Sedan (1931)
Unimog 2010 (1951)
Fiat 2300 Berlina (1966)
roenidoc is offline   Reply With Quote
Old 05-11-2026, 06:54 PM   #2
Big hammer
Default Re: Front brake Problem
That groove is for a washer with a tab , the tab keeps the washer from spinning , the wheel hub is supported by bearings so a rough axle isn’t a problem most likely. A brake locking up isn’t good !? Maybe a photo of the brake would help us with your problem .
get a bigger hammer tap done
Old 05-11-2026, 06:57 PM   #3
Bob C
The groove is to keek the bearing retaining washer from spinning.
Old 05-11-2026, 07:22 PM   #4
roenidoc
roenidoc's Avatar
Sorry, I do not know how to post my fotos here
Chris
Unimog 2010 (1951)
Old 05-11-2026, 07:46 PM   #5
roenidoc
roenidoc's Avatar
Did not work
Chris
Unimog 2010 (1951)
Old 05-11-2026, 08:17 PM   #6
updraught
updraught's Avatar
To post a photo
https://www.fordbarn.com/forum/faq.p...l&titlesonly=0
updraught is offline   Reply With Quote
Old 05-12-2026, 04:39 AM   #7
nkaminar
nkaminar's Avatar
Do you have the Flat Head Ted kit? If not then carefully inspect the wedge. If at all worn then you will need a new one. Also check that the arms are at 15 degrees forward with the brake rod off and all slack taken up. If not then you will have to add the spacer under the pin that runs through the king pin, sometimes called a "pill." Adjust the rod so that the pin slips in with the arms at 15 degrees.
There are 3 areas on the wedge corresponding to shoes retracted, shoes in normal mode, and emergency stop. The wedge should move up and down freely. I small amount of grease helps.
