Old 05-11-2026, 02:45 PM   #1
Brian54
Default Bad Vibration
My 1954 Ford Victoria (Fordomatic) is giving me fits ; it has begun to vibrate at 40 MPH and it gets worse as the speed increases . So far I have had all four wheels / tires spin balanced all to no avail . What else might be going on ; any advise would be greatly appreciated .
Brian54 is online now   Reply With Quote
Old 05-11-2026, 03:10 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: Bad Vibration
Bad U-joint in the driveshaft?
Have you replaced a brake drum recently? They can be out of balance.
Front end alignment? Worn or dry rotted rubber bushings in the front suspension?
Loose rivets or broken tabs on the flexplate? But the vibration would more likely vary with engine rpm instead of road speed. Slip it into neutral to see if the vibration goes away?
dmsfrr is offline   Reply With Quote
Old 05-11-2026, 06:30 PM   #3
Gene F
Gene F's Avatar
U-joint is the most likely.
Gene F is offline   Reply With Quote
Old 05-12-2026, 07:10 AM   #4
TedEaton
TedEaton's Avatar
Check that the bellhousing bolts are tight to the block.
TedEaton is offline   Reply With Quote
Old 05-12-2026, 10:49 AM   #5
Brian54
Great advice by all who responded ! Thank you !
Old 05-12-2026, 04:38 PM   #6
Ford Freak
When did this vibration start? Was it after you changed something on the car?
1952 Ford F1
!956 Fairlane Club Sedan
1965 Falcon Sprint
2007 Mustang GT
Ford Freak is offline   Reply With Quote
Old 05-12-2026, 06:13 PM   #7
Gene F
Gene F's Avatar
U-joints tend to be more of a time part, not a mileage part.
Old 05-13-2026, 06:50 AM   #8
Brian54
Both front drums were changed which was previously mentioned as a potential issue ; I will investigate .
