#1 |
The bezel on my 50 for the blower motor control switch appears to need a special tool to unscrew it. Has two holes 180 degrees apart. The knob and shaft can be removed for access. Any suggestions?
#2 |
#3 |
I was in a hurry, so I made one by using an appropriately sized 1/4" drive deep socket and grinding it back to make the "teeth" needed to grab the nut. Interestingly, a few year later I needed a similar tool to remove one of the dash nuts on my Corvette; I remembered the one I had made, found it in my toolbox, and it worked for that as well.
#4 | |
#5 |
