Old 05-07-2026, 11:11 AM   #1
tnhill
Default 1934 fuel pickup
I have a 1934 with a replacement tank in it made by vintique inc. I can not find a fuel pickup assembly to go in it. This tank has the 5 hole screw attachment. Everyone seems to be out of stock. Has anyone had this problem and if you did what did you do?
Thanks
tnhill is offline   Reply With Quote
Old 05-07-2026, 11:46 AM   #2
rich b
rich b's Avatar
Default Re: 1934 fuel pickup
Thanks
I usually braze a pick-up tube into the fuel sender making sure that it clears the float arm and holds about 1/4" off the bottom.
rich b is offline   Reply With Quote
Old 05-09-2026, 07:15 AM   #3
Terry,OH
Terry,OH's Avatar
The original pick up was part of the fuel level sender as well as the tank vent.
