Old 05-07-2026, 10:27 AM   #1
Thomas Sargent
Thomas Sargent's Avatar
Default slooppy steering
My 40 four door steering is sloppy. Driving down the road I need to work the wheel more than I would like. I had a mechanic try to make an adjustment on the top of the steering box but he was unable to get a full notch. Balance of steering gear is in good condition so I feel the problem is in the box. What are my options? Is there a rebuild service for this? How big of a deal is removing the gearbox and long shaft? Thanks in advance.
Thomas Sargent is offline   Reply With Quote
Old 05-07-2026, 11:04 AM   #2
hueyhoolihan
Default Re: slooppy steering
my only information is via the internet and a local hot rod expert from the 60's that said the boxes can be adjusted but only so far. and if too far the steering will get too tight, and at which point it needs to be replaced with a used one in better condition.
now i suppose that there are aftermarket rack and pinion setups or equivalents that would fix things but would involve some modifications and more work.
IME, i'm still trying to decide if i'm a victim of steering box/tierod/steering arm/king pin/ball joint wear or if the manual steering on a '41 with its enormous steering wheel just involves a lot more movement than that to which i am accustomed. ...i'm sure i've got suspension issues too!
hueyhoolihan is offline   Reply With Quote
Old 05-07-2026, 11:51 AM   #3
rich b
rich b's Avatar
We put a rebuilt unit from Lares Corp. in a '40 after determining the original box was beyond adjusting.
Not too bad of a job; just be sure to get the front up high enough.
rich b is offline   Reply With Quote
Old 05-07-2026, 12:16 PM   #4
glennpm
glennpm's Avatar
Suggest you look through and adjust with the attached instructions. There is more to it than your mechanic may be familiar with.
File Type: pdf Flathead 37 to 48 Steering Gear Adjustments.pdf (378.7 KB, 40 views)
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 05-07-2026, 12:23 PM   #5
Seth Swoboda
Seth Swoboda's Avatar
I agree with Glennpm. Follow the instructions he has provided.
Seth Swoboda is offline   Reply With Quote
Old 05-07-2026, 12:45 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
If the roller on the sector has side to side play— even just a little you won’t be able to get the play reduced— same goes for worn bushings
also the worm shaft bearings cannot have play
Old 05-08-2026, 03:18 PM   #7
alchemy
alchemy's Avatar
Haaanngg on sloopy, sloopy hang on!
alchemy is offline   Reply With Quote
