Old 05-06-2026, 07:44 PM   #1
engine103
Default Overdrive relay question
1953 Mercury 6 volt +. I'm replacing all the old cloth wiring for the overdrive and while I'm at it I'm thinking of replacing the relay. I have the smaller relay that is on the firewall but also have a larger one that I've had for many years and can't remember if the larger one is 6 or 12 Volts. Does it make a difference if it is 12 volts? Can I use it in my 6 volt system? Thanks, Jim
engine103 is offline   Reply With Quote
Old 05-06-2026, 08:02 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Overdrive relay question
Old 05-07-2026, 07:05 AM   #3
pistonbroke
That larger relay is identicle to all of the six volts I have used in the past. I don't know if they care about voltage though.
pistonbroke is offline   Reply With Quote
Old 05-07-2026, 02:04 PM   #4
JayChicago
JayChicago's Avatar
Voltage does matter for a relay, cuz 6 volts can push only half as many amps through the relay's coil as 12 volts.
But based on what Pistonbroke said, seems like that relay you have will work for you.
JayChicago is offline   Reply With Quote
Old 05-08-2026, 07:38 PM   #5
engine103
Appreciate the replies! Thanks, Jim
