Old 05-05-2026, 01:18 PM   #1
duke36
Default Full flow oil filter oil line
Regarding the oil galley end curved oil line, some are brass, some are steel. Would a firm but not super firm fit be OK? In other words, can the line be easily inserted without resistance ?
duke36 is offline   Reply With Quote
Old 05-05-2026, 01:46 PM   #2
alexiskai
alexiskai's Avatar
Default Re: Full flow oil filter oil line
My recollection on mine is that it was copper and it was a very tight fit. That’s by design because you’re trying to route all the oil under pressure into that tube.
Old 05-05-2026, 03:02 PM   #3
Werner
Werner's Avatar
Herzog,
my set included soft copper tubing. I bent it to fit without tension and finally inserted it into the delivery line with a little sealant.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 05-05-2026, 05:17 PM   #4
duke36
Thanks, I meant copper. Mine is steel I 'm afraid to use sealant that may push out towards the front bearing hole. The pipe doesn't move when installed.
Old 05-06-2026, 06:07 AM   #5
Randall
Randall's Avatar
If it goes in loose insert a tapered punch in the end of copper tube and roll it around to make it a snug fit when you slip it in the galley, https://youtu.be/1RrgR4SKsj8?si=xOn202j3u74XYzPT
Randall is offline   Reply With Quote
