Old 05-03-2026, 07:02 AM   #1
allenmichael
Default 1936 model 68 lift points
Curious as to what all think are the best lift points on a 36 model 68 with a modern two point lift.
allenmichael is offline   Reply With Quote
Old 05-05-2026, 02:44 PM   #2
Zeke3
Zeke3's Avatar
Default Re: 1936 model 68 lift points
BTT
I assume you mean a two post lift, please clarify. I have never lifted my 1937 on this type of lift, but I lifted it many times on a single post lift when I worked at the gas station, back in the dark ages. I always lifted it where the X section meets the outer frame rails because there is double thickness of the frame flanges there.
Zeke3 is offline   Reply With Quote
Old 05-05-2026, 03:41 PM   #3
1stford
1stford's Avatar
Maybe a dumb question but is it the same frame as a 36 truck you think?
1stford is offline   Reply With Quote
Old 05-05-2026, 04:02 PM   #4
Model51
Model51's Avatar
Pickup? yes, because it has essentially the same frame as the car. The Ford Truck has a completely different and much larger frame (131 1/2" and 157" wheelbase in 1935-36).
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 05-06-2026, 07:08 AM   #5
allenmichael
My bad, yes a two post lift
