Old 05-02-2026, 08:49 PM   #1
oldgas
Default Alternator
Can anyone shed light on where I can purchase an alternator bracket kit for my 292 Y-block engine & what alternator to use.
Thank you for your time in advance
Oldgas:
oldgas is offline   Reply With Quote
Old 05-02-2026, 09:31 PM   #2
51504bat
51504bat's Avatar
Default Re: Alternator
These guys:
https://www.qualitypowerauto.com/ite...-and-newer.htm
Not cheap but I've used them for GM alternators and brackets for several 8ba flatheads as well as a 3g alternator for the 302 in my Ranch Wagon.
But not positive this one will work on a Y block or not. Best to give them a call.
Old 05-02-2026, 10:09 PM   #3
miker98038
miker98038's Avatar
Mummert makes a nice one, but not for a bird .
www.ford-y-block.com/alternatorbrkt.htm
miker98038 is offline   Reply With Quote
Old 05-03-2026, 12:02 AM   #4
dmsfrr
dmsfrr's Avatar
old gas
The generator/alternator in a T-Bird sits lower and closer to the engine than in other Y-block powered vehicles.
Their brackets won't be interchangeable.
dmsfrr is offline   Reply With Quote
Old 05-03-2026, 04:36 AM   #5
raceron1120
raceron1120's Avatar
Perhaps something to consider - a possible alternative is a PowerGen alternator, I had one installed on my '56 about 15-20 years ago. Looks like the generator & used the original brackets. Costly but can't remember what I paid for it back then.
raceron1120 is offline   Reply With Quote
Old 05-03-2026, 11:32 AM   #6
RKS.PA
RKS.PA's Avatar
Check out the one at CASCO . I have that one on my '56 T Bird and it's worked very well for me. As noted above, not cheap....$289...easy to bolt on and wire up.
RKS.PA is offline   Reply With Quote
