Old 05-02-2026, 06:17 PM   #1
40larry
Default Ethanol Resistant Fuel Flex Line
Are the ethanol resistant fuel flex lines still available ? How do you contact the seller ?
40larry
40larry is offline   Reply With Quote
Old 05-02-2026, 07:34 PM   #2
Seth Swoboda
Seth Swoboda's Avatar
Default Re: Ethanol Resistant Fuel Flex Line
Bob Schuman sold them, but someone recently said he had quit.
Seth Swoboda is offline   Reply With Quote
Old 05-03-2026, 01:16 PM   #3
JayChicago
JayChicago's Avatar
I would assume any fuel product made in the last twenty years is compatible with ethanol.
https://thirdgenauto.com/product/193...-to-pump-hose/
JayChicago is offline   Reply With Quote
Old 05-04-2026, 05:46 AM   #4
TomT/Williamsburg
TomT/Williamsburg's Avatar
I normally use fuel injection hose ....
TomT/Williamsburg is offline   Reply With Quote
Old 05-04-2026, 09:16 AM   #5
wga
wga's Avatar
Hose-Man (14525 Firestone Blvd, La Mirada
Bit of a drive from Northridge. Take the hose you have with the fittings, and they will match the ends, with a hose compatible with all the fuels. 10 minutes and you are out the door. There is a Chic Fil A and In N Out near by.
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 05-06-2026, 09:03 PM   #6
barnfind
Marine supply houses should have it as well. Fuel line deterioration is a very common problem even on fuel injection motors depending on the vintage.
barnfind is offline   Reply With Quote
