Old 05-02-2026, 04:30 PM   #1
jdjj
Default 1935 pickup side window mechanism
Are the side window mechanisms interchangeable? Drivers side passenger side?
jdjj is offline   Reply With Quote
Old 05-02-2026, 05:19 PM   #2
ford38v8
ford38v8's Avatar
Default Re: 1935 pickup side window mechanism
Nope. Each is different side to side, even between same sides on different models of the same years. Regulators are not cheap, so examine closely to determine if repairable. Gear teeth can be welded back and filed down to work properly.
Alan
Old 05-02-2026, 07:57 PM   #3
Don Rogers
Don Rogers's Avatar
Here's what left and right regulators look like!!!!
Don Rogers is offline   Reply With Quote
Old 05-02-2026, 08:19 PM   #4
jdjj
thanks for the great pics. I assume left side is drivers side?
Old 05-02-2026, 08:41 PM   #5
petehoovie
petehoovie's Avatar
Old 05-02-2026, 09:11 PM   #6
tubman
tubman's Avatar
In the USA and a lot of the rest of the world, yeah. When referring to a specific side of a car, using "left" and "right" is unambiguous. "Drivers" and "passengers" are confusing since the Brits and their ilk have chosen to drive on the wrong side of the road.
Old 05-05-2026, 08:56 AM   #7
Ngnear22
Ngnear22's Avatar
Slightly off topic, but the glass lift channels for each mechanism are also "handed" and I'm finding they are very difficult to find. I'm still looking for a 36 Pickup RH (passenger side) lift channel if anyone has a source that isn't out of stock.
Ngnear22 is offline   Reply With Quote
Old 05-07-2026, 06:45 PM   #8
Kube
Super Moderator
Kube's Avatar
Regardless of where the car resides, the left or right side of the car is ALWAYS determined by sitting in the car and looking forward.
If the car you are sitting in has the steering wheel on the left, then yes, the left is the driver's side.
Old 05-11-2026, 08:40 AM   #9
Kens 36
Kens 36's Avatar
Mike,
Agree with you fully - simplest and best explanation.
But then there is this one....
Ken
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 05-11-2026, 09:48 AM   #10
Als48
Originally Posted by Kens 36 View Post
Mike,
Ken
But Ken, are those suicide doors on the front or the back of that '57?
Als48 is offline   Reply With Quote
Old 05-11-2026, 10:46 AM   #11
petehoovie
petehoovie's Avatar
Mike,
Ken
Old 05-11-2026, 02:25 PM   #12
Kens 36
Kens 36's Avatar
Yes.
Old 05-11-2026, 03:37 PM   #13
tubman
tubman's Avatar
They're ALL suicide doors on a car like that!
Old 05-11-2026, 04:41 PM   #14
Jeff/Illinois
Jeff/Illinois's Avatar
And to add further, left side is always numbered an odd number in the basic part number in the Ford Parts Numbering system. And yes they determined as Kube says, you are sitting in the car facing the front...
I often wondered 'how' in Great Britain or Australia, they hand-signalled a left hand turn from the right hand side of the car...they must have had one heck of a long arm !
Jeff/Illinois is offline   Reply With Quote
Old 05-11-2026, 09:30 PM   #15
Model51
Model51's Avatar
One exception to the rule of left side being even numbers and right side is odd numbers are the 6049 (RH) and 6050 (LH) heads.
The head for a four cylinder engine is 6050 and the gasket is 6051 so maybe someone got the idea that it would be better to have consecutive numbers for heads and decided 6049 was logical. I don't know how someone decided which was LH and RH, but it's one exception to the rule.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 05-12-2026, 09:15 PM   #16
325w
Had a lady inspector in the car factory. If she was looking at the front the left was right. From the rear right was right. Hard to repair with her.
325w is offline   Reply With Quote
