#1 |
Hi; I have a tool trunk on the front of my 1930 model A. It covers the Engine Crank access. It seemed to me that I saw at one point an Engine Crank for timing that worked inside the engine compartment. It was an L shaped engine crank. Does anyone have any information on it or where they might sell them?
Mike |
#2 |
#3 |
Here is a tip for the crankshaft ratchet nut wrench.
Bob Bidonde |
#4 |
Thanks Guys!
#5 |
Suggest you check the size of the ratchet nut before purchasing or fabricating one of the offset wrenches. Standard (stock) size is 1&3/8", but it's possible the nut has been replaced w/a different size, some variations are 1&5/16" and 1&1/4".
#6 | |
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan (under reconstruction) 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
#7 |
You can cut a hole in the back of the tool box and use the standard hand crank. You cannot do a complete 360, but you can do 90 degrees and then reset the crank.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 05-02-2026 at 07:56 PM. |
#8 |
Paul Shinn has a vid out where you buy a cheap harbor freight wrench and modify it to work. He has all the dimensions of where to make the bends. I used this and it worked out perfect!
#9 |
You could cut two holes in the box front and rear , cut the hand crank into, weld a extension making the crank extra long, and hand start the motor ! you might need to manufacture some sort of a bearing for the front tool box hole though. Then wear would you store the extra long crank and then how to seal the holes in the box . With the box ended tool I find it hard to get less than a 1/4 turn and having to jam the wrench in to the fan belt to be able get the wrench off and another bite on the nut , along with an aching back ! Thankfully I use the setting the timing and forget about it Tom Wesenberg’s method timing ! Miss Tom a lot !
#10 |
#11 |
No need to weld a longer crank —V8 ones have a extension
I have found putting the trans in 3 rd gear and moving the car with the front wheel while pushing the timing pin works perfectly fine when checking timing |
#12 |
