Old 04-28-2026, 01:53 PM   #1
Trapdoor2
Trapdoor2's Avatar
Default Repair worn threads for floorboard screws.
Having had the floorboards out a time or three whilst recently speedometer cabling, I was wondering how to repair the 12-24 threads for the floorboard screws. Several of mine are barely there. A couple appear to have been beaten into submission with a body dolly and a ball-pein hammer (and then badly re-tapped). It appears to me that floorboard removal/replacement is one of those jobs that just never end. I'd like to have screws that actually work (the screws are actually fine, and I have a full set of washers too).
I suppose there is a "correct" way and...everything else.
Having done my time with sheet metal, I was thinking it should be a good place for a rivnut. McMaster-Carr sells a bag of 10, 12-24 rivnuts for ~$8. I actually think I have a rivnut tool around here somewhere...but surely not specific for 12-24.
Are rivnuts taboo? Should I use acupuncture? Chair Tai Chi? Cinnamon and vinegar?
'31 Ford Deluxe Coupe "The Green Hornet"
Trapdoor2 is online now   Reply With Quote
Old 04-28-2026, 02:28 PM   #2
Joe K
Joe K's Avatar
Default Re: Repair worn threads for floorboard screws.
Heli-coil inserts.
Ebay search Helicoil KIT 12-24
The kit including the tap and an insertion wrench is a little pricey at $38.67 plus ship. But the helicoil "spirals" are sold separately pack of 12 for $10.96 free ship.
You should look around both Ebay and Amazon. You may find a better deal.
Doing helicoil is one of those things I LIKE to do. Almost flawless - as long as you don't break off the tap.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 04-28-2026, 02:47 PM   #3
Oldgearz
I replaced mine with metric screws slightly larger than existing size. Tapped new threads Therefore only had to buy screws and tap. Pretty cheap and not too much work
Oldgearz is offline   Reply With Quote
Old 04-28-2026, 03:35 PM   #4
Trapdoor2
Trapdoor2's Avatar
Originally Posted by Joe K View Post
Heli-coil inserts.
Joe K
I have 12-24 Helicoils on hand...but this is sheetmetal...well, the ones that have been beaten flat are. I might get 2 complete threads.
Old 04-28-2026, 03:48 PM   #5
Oldbluoval
Oldbluoval's Avatar
Never done it……re-tap to 1/4-20??
Oldbluoval is offline   Reply With Quote
Old 04-28-2026, 04:29 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
I'm a fan of rivet-nuts. Bolt Depot has a good selection plus installation tools but I don't see 12-24? McMaster-Carr does not list a 12-24 Rivet-nut either. www.boltdepot.com
Old 04-28-2026, 04:58 PM   #7
figment
You could replace the D nuts and order a set original screws from one of the suppliers. Snyders or Berts should have the D nuts . It shouldn't be to hard to remove the bad ones and all you have to do is pean the new ones to hold them in place .
figment is offline   Reply With Quote
Old 04-28-2026, 05:09 PM   #8
nkaminar
nkaminar's Avatar
Instead of going all the way to 1/4 screws, you could go to 14-24 screws which are slightly smaller.
Old 04-28-2026, 05:50 PM   #9
Synchro909
Synchro909's Avatar
Even if your are chasing originality/judging, do the judges even look at those threads? I very much doubt it. My cars are drivers so none of that matters a skerrick. I put a 1/4" X 20 tap in the battery drill and ran it through the old holes. Those weird "gauge" screw sizes puzzle me and 1/4" W is (or was) readily available. It was a no brainer for me. As for the washers, I took a few ordinary 1/4" washers and with one whack from a hammer, made them conical. The floor boards didn't complain!
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 04-28-2026, 08:51 PM   #10
David in San Antonio
David in San Antonio's Avatar
I bought a set of floorboard screws and they fell into place with no turning required. Maybe one grabbed a thread. It seems the original D-nuts were wallowed out. So this thread could prove useful.
Now I have to look up the original meaning of skerrick.
Late ‘30 Deluxe "Wretched Roadster"
1931 Slant Windshield Fordor “Earl Gray”
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 04-28-2026, 09:50 PM   #11
1crosscut
1crosscut's Avatar
I rather like Oldgearz solution in post #3
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 04-29-2026, 08:08 AM   #12
Jim/GA
Jim/GA's Avatar
I did a helicoil on a couple and I was not impressed. There is nothing there to hold the coil in place. It wants to screw all the way through as you install the floorboard screw. I tried a drop of thread lock but it didn’t hold.
Tapping to a larger size screw works.
Or replace the d-nut before you paint.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 04-29-2026, 09:31 AM   #13
katy
katy's Avatar
Skerrick = smidge
Old 04-29-2026, 10:39 AM   #14
Trapdoor2
Trapdoor2's Avatar
https://www.mcmaster.com/products/ri...ad-size~12-24/
I would not have an issue with going to a larger fastener, such as 1/4", if I had to. My Coupe isn't and won't be a show car, even though I prefer keeping it as "stock" as I can. I try to not use obviously modern drive types, such as Phillips but I might make an exception for heavy-use pieces like the floorboards. The screws are hidden under the carpet anyway.
Old 04-29-2026, 10:44 AM   #15
gdmn852
gdmn852's Avatar
Hello, the d nuts with 12-24 threads are also available from Snyders, I just drilled out the original stripped out ones and replaced them with the d nuts, penning them over to hold them in the body , also had to do this on some of the cowl nuts that hold gas tank. The 12-24 threads are rarely used anymore, normally go from 10-32 to 1/4 -20 or 24 , more recently metric. 6 mm might be used to retap the existing threads.
gdmn852 is offline   Reply With Quote
Old 04-29-2026, 11:32 AM   #16
Bob C
Time-sert has a 12-24 kit that may work better than a Helicoil.
https://time-serts.com/store/12-24-thread-repair-kit/
Bob C is online now   Reply With Quote
