Old 04-24-2026, 06:35 PM   #1
Automotive Stud
Automotive Stud's Avatar
Default Upper steering column bushing or bearing?
Am I missing something here? This is my dad's model A, I think the column is f100 but it could be 51 car also, I'm not really sure. The steering wheel is a little wobbly at the top. At first I thought it was missing the cone and spring, but after taking the steering wheel off I'm not sure that's what it's supposed to have. It looks like it might just be a bushing that's a little loose.
Automotive Stud is offline   Reply With Quote
Old 04-24-2026, 09:27 PM   #2
Oldcarbearings
Location: North Warrandyte, Melbourne,Victoria, Australia
Default Re: Upper steering column bushing or bearing?
There's a bearing&plastic sleeve that the bearing fits/sits inside so as not to wear the shaft,
There's also a conversion kit that uses a rubber housing &bronze bush here's the ford part number : 51A-3517-A,
IMHO&HO (honest&humble opinion) i'd go with the bearing&plastic sleeve as a bronze bush will wear the shaft plastic being a softer material won't......
Oldcarbearings is offline   Reply With Quote
Old 04-25-2026, 12:00 AM   #3
petehoovie
petehoovie's Avatar
Old 04-25-2026, 06:04 AM   #4
rich b
rich b's Avatar
Should be a bearing in there (maybe the outside shell is still there) along with a cone that centers the shaft in the bearing, and a spring under the wheel to bear down on the cone.
The F series bearing and modern plastic cone are circled in the picture.
Available from the usual Ford parts suppliers.
File Type: jpg IMG_20190210_091224 - Copy (Medium).jpg (35.0 KB, 99 views)
rich b is offline   Reply With Quote
Old 04-25-2026, 08:30 AM   #5
Automotive Stud
Thanks Rich. That's what I was thinking also. I've seen the bushing on the left of your picture and I think that's what I'm looking at in there. I didn't know if the column took that or the bearing and cone instead or both.
Old 04-25-2026, 10:23 AM   #6
petehoovie
petehoovie's Avatar
Old 04-25-2026, 11:05 AM   #7
TJ
TJ's Avatar
Try to get the old bushing out and replace with the bearing and tapered sleeve.
Old 04-25-2026, 03:33 PM   #8
Automotive Stud
Looks like when my dad put it together he used an early style bushing, but it's either worn or not tight enough. I ordered a bearing and cone and a few different style bushings to play with. I'll make something work.
Old 04-25-2026, 07:02 PM   #9
petehoovie
petehoovie's Avatar
