Old 04-22-2026, 01:26 PM   #1
oldford2
oldford2's Avatar
Default 46 sedan
Where is the fuse for the dash gauges? they are not working.
Thanks
John
oldford2 is offline   Reply With Quote
Old 04-23-2026, 07:01 AM   #2
maineford
Default Re: 46 sedan
It is a circuit breaker system
maineford is offline   Reply With Quote
Old 04-23-2026, 12:33 PM   #3
JayChicago
JayChicago's Avatar
The two circuit breakers are one for the headlights, one for all other lights. Power to gauges comes directly from ignition switch. No fuse or circuit breaker for the gauges.
JayChicago is offline   Reply With Quote
Old 04-23-2026, 01:24 PM   #4
rotorwrench
rotorwrench's Avatar
Let the troubleshooting commence. Apply six volts to each isolated indicator and see if it moves the needle. The King Seeley water temp ones move the other way. They go full hot with no power applied and full cold with power. If the indicators work then the senders are suspect. Make certain all wiring has continuity between senders and indicators. Make sure the power is getting from the switch to the indicators. The coolant temp and oil psi senders ground to the engine. The fuel quantity grounds to the frame through the tank attachments.
Old 04-24-2026, 09:56 AM   #5
1942deluxe
1942deluxe's Avatar
Really unusual to lose all the gauges at once. As mentioned, there is a terminal on the back of the ignition switch marked "gages". Check that for a voltage reading. On the circuit breaker all the terminals should read approximately 6.3 volts.
1942deluxe is online now   Reply With Quote
Old 04-24-2026, 11:47 AM   #6
Seth Swoboda
Seth Swoboda's Avatar
Rotor and 42deluxe have good advice. Get yourself a multi-meter, start checking for voltage at the gauge and working your way back. You will find the problem.
Seth Swoboda is offline   Reply With Quote
Old 04-24-2026, 11:56 AM   #7
TJ
TJ's Avatar
This poster asked the same question on the V-8 Club site and it concerned the dash lights for the gauges. He did get and answer over there. This new post now talks about the gauges. Not sure what he really wants to know? Hopefully he will clarify it.
