Old 04-20-2026, 02:15 PM   #1
Ronnieroadster
Ronnieroadster's Avatar
Default 1946 to 1948 59A oil pan capacity
Question about oil pan capacity. Wondering what the actual Ford required oil capacity is for the 59A oil pan is it four or five quarts? Have dip sticks with various full marks. Once I know the actual Ford capacity I can check the dip sticks to find the correct ones.
Ronniroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 04-20-2026, 03:43 PM   #2
19Fordy
19Fordy's Avatar
Default Re: 1946 to 1948 59A oil pan capacity
Here's the answer.
https://www.google.com/search?q=ford...hrome&ie=UTF-8
Old 04-20-2026, 04:35 PM   #3
Kube
Super Moderator
Kube's Avatar
Ronniroadster
The engineering drawings clearly depict five US quarts. It does NOT matter whether or not there is / was a filter.
I still don't understand why this four quart "theory" is still out there.
That google link posted in a previous response is full of inaccurate information.
Old 04-20-2026, 07:50 PM   #4
Brian
Brian's Avatar
With respect Mike, possibly because 4 imperial quarts equates to five of your yankee quarts...Here in New Zealand, I fill my flatheads with 4 [imperial] quarts....
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 04-20-2026, 11:55 PM   #5
cas3
Up until the Japanese invasion in the 70's, I think every car on the road took 5 US quarts.
I worked at a gas station in my teens, we put 5 quarts in without looking.
cas3 is online now   Reply With Quote
Old 04-21-2026, 01:58 PM   #6
The Art Doctor
The Art Doctor's Avatar
When i put 5 in the early motor with no rear main seal it winds up on the ground very quickly at each time I turn of the motor. With only 4 in there the puddle is significantly smaller at each engine shutdown. A previous owner scratched in a line on the dip stick at 4 and I at first ignored it and put in 5. Well very quickly it was down to that mark. Losses from there are much slower. Next change i will put in only 4 and keep the giant puddles at bay and save the extra to top back up to 4 when needed. The factory DANGER mark is 3 quarts on my dipstick.
The Art Doctor is offline   Reply With Quote
Old 04-21-2026, 02:44 PM   #7
19Fordy
19Fordy's Avatar
Thanks Kube for the correct info.
Old 04-21-2026, 03:19 PM   #8
Ronnieroadster
Thanks for the information everyone since I'm in the United States 5 quarts will be the capacity I work from.
Ronnieroadster
Old 04-21-2026, 03:28 PM   #9
Tim Ayers
5 quarts is what I've been using as well. It is a little maddening that you need to use the corresponding dip stick for the pan. It seems that '49-'53 dip sticks are marked with an engine series and the earlier ones are not.
Old 04-22-2026, 09:14 AM   #10
Kens 36
Kens 36's Avatar
Not quite. The 1949 - 1951 Mercury engines held 6 quarts. Lincolns of the same years held 6 1/2 quarts. Just a couple of examples, I'm sure there are more.
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 04-22-2026, 10:21 AM   #11
Kube
Super Moderator
Kube's Avatar
Incorrect dipstick and / or sludge in the pan will cause those issues.
Old 04-22-2026, 10:22 AM   #12
Kube
Super Moderator
Kube's Avatar
Ha! A great reason back then to tell the jockey "no thanks, I'll take care of it myself".
Old 05-13-2026, 07:55 AM   #13
Ron_r1959
Ron_r1959's Avatar
I think somewhere I read when Henry first come out with the v8, they held 4 quarts, they apparently had a oil consumption problem initially so he added a extra quart to help buy some time I suppose. Maybe that original 4 quart capacity just stuck in peoples head? I heard that over the years many times and I have also heard about the oil leaks getting worse with 5 as mentioned above, but I know on mine, I run 5 quarts just because I can I guess. It makes me feel better on long runs since mine is a driver.
Ron_r1959 is offline   Reply With Quote
Old 05-15-2026, 02:01 PM   #14
big job
big job's Avatar
my 59 AB when I put 4 qts stick reads full. another qt reads over full mark. (no filter) I go around the block now it reads full. engine has only 10,000 miles . no sluge it was thermo baked came back pure cast as new. I also have couple F6's 5 qts my F8 337 0 qts.
so I say 5 quarts from 59A to 8ba's.
big job is offline   Reply With Quote
