Old 04-18-2026, 08:04 PM   #1
oldgas
Default steady rest
Did Ford discontinue the front steady rest on the 1956 Ford Fairlane line-up late in the year of 1956?
If Ford did this can i assume the steady rest is not essential at a motor mount & would be safe to not install it?
Thank you for your time in advance.
Old Gas
oldgas is offline   Reply With Quote
Old 04-19-2026, 10:21 AM   #2
5851a
Default Re: steady rest
I don't know if it discontinued but think a lot of people got rid of them during engine swaps. Defiantly not used when a FE engine was installed.
5851a is offline   Reply With Quote
Old 04-19-2026, 10:25 AM   #3
Jim.UT
Jim.UT's Avatar
My 55 still has it but it also still has the original Y-block. As for deleting it, I always go back to the idea that a manufacturer never adds a piece to a car unless it's necessary. Why would they increase the cost of the car unnecessarily?
Jim.UT is offline   Reply With Quote
Old 04-22-2026, 05:47 PM   #4
craig
Ford did call it a steady rest, not a motor mount to begin with. It was gone on my '56 when I got it and so far, I haven't missed it. I remember a friend back in the '60's telling me it was designed to help prevent clutch chatter as the motor mounts aged and became softer.
craig is offline   Reply With Quote
Old 04-22-2026, 08:06 PM   #5
paul2748
paul2748's Avatar
The steady rest was on my car (original 239?). When I changed it to a 312 I kept the steady rest (but did have get a 55). I figured it would cause less wear and tear on the engine/trans mounts.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-27-2026, 04:30 PM   #6
Bleach
Bleach's Avatar
Still present on my ’56. My car has an automatic so there must be another reason for it.
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic
Bleach is offline   Reply With Quote
Old 04-27-2026, 04:35 PM   #7
Bleach
Bleach's Avatar
OK, according to Y-blocksforever, “The Y-block steady rest, used on 1954-1956 Ford engines, was designed to enhance engine stability and reduce cabin vibrations by supporting the front of the engine, often dubbed a "freeway hop" dampener. It linked the engine to the frame crossmember to reduce resonant vibrations on older chassis, though it was discontinued for 1957 when frames were strengthened.”
Old 05-28-2026, 06:18 PM   #8
41Fordor
41Fordor's Avatar
The only problem I noticed in my 1954 Customline when I swapped the 292 in was I couldn't use the thicker harmonic balancer. My machinist balanced it anyway and I just used it with the 239 pulley and timing cover to look original.
41Fordor is offline   Reply With Quote
