Old 04-18-2026, 04:25 PM   #1
Redhorse1947
Redhorse1947's Avatar
Default 1950 Flathead-What is this object"
After taking the intake manifold off I found this object. Does anyone recognize what it might be?
It was in the very back of the valley.
it measures appx. 5/8" high and 1/2" across. Appears to have been circular shaped.
Engine has adj lifters with 8,000 miles.
Thank you for taking the time to read my post!
Redhorse1947 is offline   Reply With Quote
Old 04-18-2026, 04:30 PM   #2
Brian
Brian's Avatar
Default Re: 1950 Flathead-What is this object"
it is a part of the fuel pump lever mechanism that has fallen off.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 04-18-2026, 06:40 PM   #3
petehoovie
petehoovie's Avatar
Old 04-18-2026, 08:34 PM   #4
19Fordy
19Fordy's Avatar
It looks like some type of clip. Perhaps it accidently fell into the engine when the intake was removed and no one noticed.
Old 04-18-2026, 08:34 PM   #5
Redhorse1947
THANK YOU so much! I can now have a restful sleep tonight!
Old 04-19-2026, 05:48 AM   #6
Terry,OH
Terry,OH's Avatar
Yes the end of the fuel pump operating arm. This cage keeps the push rod under the operating arm. Appears to be broken off the pump operating arm.
Old 04-19-2026, 09:10 AM   #7
pistonbroke
On an offshore made pump I bought new that clip had fallin off while it was still in the box.
pistonbroke is offline   Reply With Quote
